U4GM: How to Beat Commando Chick in Bee Swarm Simulator
In Bee Swarm Simulator, Commando Chick is one of those enemies that seems harmless at first, but quickly earns its reputation as a mini-boss you can't ignore. It lives in its own lava-filled room and mixes a steadily increasing health pool with grenades and contact damage, which means fights are less about rushing it down and more about staying alive while your bees slowly wear it down. If you want to farm it efficiently, it helps to know where it is, how it attacks, and why its rewards are worth the effort Bee Swarm Simulator Items.
You'll find Commando Chick's hideout in the Starter Zone, just to the left of Brown Bear and the Wealth Clock. The entrance is blocked by vines when you first arrive, so you'll need a cutting tool like Clippers, Scissors, or a Scythe to clear the way. Once inside, you cross a short staircase over lava and drop into a small arena where the fight begins immediately. The room is tight, which makes movement and positioning a lot more important than raw damage, especially early on.
During the fight, Commando Chick alternates between chasing you and retreating into its shell to throw grenades. Running into it deals around 20 damage, while getting caught in an explosion can hit for roughly 50, which adds up fast if you're not paying attention. When it hides in its shell, it takes much less damage and starts tossing grenades in patterns that get more intense as its health drops. At higher health it throws one at a time, then two, then three, and eventually four when it's nearly defeated, forcing you to keep moving and watch the floor constantly.
What really sets Commando Chick apart is how it scales. The first few captures are fairly easy, starting at low level and around 150 health, but every time you defeat it, its level and health increase. After enough captures, it can reach massive health values, turning each encounter into a longer battle that rewards stronger bees and better hive setups. If you leave the room mid-fight, its remaining health stays the same, so you can slowly chip away at tougher versions over multiple attempts while you work on upgrading your swarm.
Most players focus on survival first and damage second. Running in a loose circle around the room, jumping over Commando Chick when it charges, and sidestepping grenades right before they explode is usually the safest approach. Some players use a positioning trick near the edge of the final staircase by the entrance, where your bees can still attack while the chick struggles to reach you, though this can be inconsistent and sometimes causes it to move unexpectedly. As your bees get stronger, the fight becomes much more manageable and far less risky.
The real motivation for fighting Commando Chick over and over is its reward track. In addition to regular drops, certain capture milestones guarantee valuable items. Early milestones include Glue, a Gold Egg, Star Jelly, Blue Extracts, Tickets, and Stingers. As you push further, the rewards become more significant, with items like a Mythic Egg at 50 captures, a Star Treat at 100, and eventually a Commander Bee Egg at 200 captures. Because of this, Commando Chick is less of a one-time challenge and more of a long-term investment in your account's progression.
With a respawn timer of about 30 minutes, slightly shorter if you own a Gifted Vicious Bee, Commando Chick fits neatly into a regular farming loop. You can defeat it, move on to quests, fields, or other bosses while it's on cooldown, then return when it respawns to keep stacking captures Bee Swarm Simulator items for sale. Over time, those repeated fights add up to some of the game's most valuable rewards, and learning to handle Commando Chick efficiently becomes an important step toward late-game progress in Bee Swarm Simulator.
