How to Use Parachute in GTA 5 U4GM Beginner Guide
If you want to survive jumps from helicopters, aircraft, mountains, or tall buildings, learning how to use a parachute in GTA 5 is essential. Whether you are exploring Los Santos or building up your collection of GTA 5 Modded Accounts, knowing when and how to deploy a parachute can make a huge difference. The parachute is easy to use once you understand the controls, but timing, steering, and landing technique are important if you want to avoid hitting the ground at high speed.
Getting a Parachute
Before you can use a parachute, you need to obtain one. In GTA 5 Story Mode, parachutes can become available after progressing through certain parts of the game. You can also find parachutes at specific high-altitude locations, such as certain helicopter landing areas and mountain viewpoints. In GTA 5 Online, parachutes are much easier to access. Players can generally purchase parachutes and customize them through Ammu-Nation after unlocking the relevant options.
Once you have a parachute, it is stored in your character's inventory. You do not normally need to equip it manually every time you jump. When you leave an aircraft or perform an appropriate high-altitude jump, the game can automatically provide the parachute when conditions allow.
How to Deploy the Parachute
The first important skill is knowing when to open the parachute. After jumping from a plane, helicopter, or high location, your character will initially fall freely. During this period, you can control the direction of the fall.
On PC, the parachute can generally be deployed using the designated parachute key, commonly the F key under default controls. On PlayStation and Xbox controllers, the deployment control is typically associated with the left shoulder button. Because controls can be customized, checking your current key bindings is recommended if the default command does not work.
Do not wait until the last possible moment to deploy. Opening the parachute too early can give you a longer glide, while opening it too late can result in a dangerous landing. For beginners, deploying the parachute with plenty of altitude remaining is the safest approach.
Steering While Parachuting
Once the parachute opens, you can control your character's movement. The left analog stick or corresponding keyboard controls allow you to steer left and right. Moving forward can increase your horizontal speed, while pulling back can help slow your descent.
Look ahead and identify a safe landing area. Large roads, beaches, open fields, and flat rooftops are usually easier targets than narrow streets or areas filled with obstacles. You can also use the camera to monitor your surroundings while adjusting your direction.
Practice is particularly useful because parachuting has momentum. Sharp movements can change your trajectory quickly, but smooth adjustments generally make it easier to land accurately.
Landing Safely
As you approach the ground, reduce your forward movement and try to approach the landing area from a controlled angle. Avoid steering aggressively during the final seconds. If you are moving too quickly, you can easily hit a wall, vehicle, tree, or other obstacle.
A successful landing usually requires you to touch down on relatively clear ground while maintaining reasonable control. If you are attempting a stunt, landing accuracy becomes even more important because narrow platforms require careful steering.
Using Parachutes for Missions and Exploration
Parachutes are useful beyond simple stunts. Several GTA 5 activities involve jumping from aircraft or descending from elevated locations. They are also useful for reaching unusual areas, escaping dangerous situations, and experimenting with Los Santos' vertical environment.
The best way to improve is to practice repeatedly from different heights. Try jumping from a helicopter, opening the parachute at different altitudes, and aiming for specific locations. With enough practice, you will quickly learn how much time you have to steer and slow your descent.
Ultimately, understanding parachute deployment, steering, and landing will make aerial activities much more enjoyable. Once these basics become second nature, you can focus on more advanced jumps while enjoying the freedom and variety that GTA 5 offers. Whether you play casually or manage several GTA V Accounts, mastering parachuting is a useful skill for exploring the game.
Getting a Parachute
Landing Safely
