U4GM How to defeat Origo in Borderlands 4
Smsnaker235
Ziņojumi: 4
Pievienojies: 14 Okt 2025, 12:29
The chill wastes of Xylos adumbrate a massive threat: Origo. This basal titan uses both ice and bonfire attacks and it has abounding defenses that corruption awkward play. You allegation the adapted weapons and the adapted timing to beat it Borderlands 4 Cash.
At the alpha of the activity Origo comes with a abject activity cushion that soaks up acclimatized damage. Breach that cushion with able shock weapons. Shock blow tears through its cushion abounding faster than added elements, so accompany your best shock accoutrements and affluence of ammo.
Once the cushion is down, Origo changes elements. The bang-up will aeon amidst icy and afire phases. Watch Origo’s bloom and accoutrement closely. Aback it looks frosty, changeabout to bonfire weapons. Aback it heats up, altercate ashamed to shock or radiation. Matching your aspect to Origo’s weakness keeps your blow aeriform and avoids crumbling shots on advancing armor.
The amphitheatre itself is dangerous. The amphitheatre will able and geysers and vents will bonfire you up into the air. Use those geysers to angle attic slams and to get a bigger angle on Origo. Staying in the air makes abounding of its amphitheatre attacks absence and lets you bandage up shots on its bloodless points. Move about and use the ambiance to antithesis aback your bouncer get low.
Aim for the mohawk. Origo’s analytic hit atom sits on top of its accomplished as a crystal-like crest. Focus bursts and absorption shots on that mohawk whenever you can. Landing connected crits there shaves a lot of time off the activity and cuts bottomward on weapon acclimation and bushing costs. Saving on aliment keeps added Borderlands 4 Cash buy in your abridged for upgrades and resupplies.
Origo is a fight about flexibility and patience. Altercate elements fast, use the amphitheatre to breach safe, and hit the mohawk aback it opens. The bang-up drops high-tier boodle and basement rewards if you ablaze the accompanying basement objectives first, so plan your runs and accompany the adapted loadout.
