Fortnite Cheat Codes Guide: Locations, Rewards, Rarity, and Cheat Master
Fortnite Chapter 7 Season 4 adds a new way for players to discover Sprites through the introduction of Cheat Codes. These glowing interactive sequences have replaced Sprite Chests and can appear across the Battle Royale island.
Instead of simply opening a container, players must interact with a Cheat Code and reproduce a sequence of directional inputs. While the mechanic may seem complicated at first, it becomes much easier once you understand how Cheat Codes work and unlock the Cheat Master Sprite.
Here is everything you need to know about finding Cheat Codes, entering their sequences, understanding rarity, and using Cheat Master to speed up the process.
What Are Fortnite Cheat Codes?
Cheat Codes are special interactive objects that can randomly appear on surfaces throughout the Battle Royale map. They may be found attached to walls or directly on the ground, so players should keep an eye on their surroundings while exploring.
These codes can produce audio cues similar to treasure chests, while visual sound effects may also help reveal their location.
Once you find one, you'll see a series of directional arrows. The objective is to reproduce the sequence correctly. Completing the sequence rewards you with a Sprite.
Don't confuse these objects with Lobby Hack codes. Although both systems use the word "code," they serve different purposes. Lobby Hack codes are connected to the season's special interface, while Cheat Codes are physical objects that players encounter during Battle Royale matches.
How to Complete a Cheat Code
Completing a Cheat Code is relatively straightforward once you know the process.
Step 1: Locate a Cheat Code
Explore the island and listen for its audio cue. Visual sound indicators can also make the search easier.
Step 2: Interact With It
Move close to the object and select ENTER CHEAT.
Step 3: Memorize the Sequence
A series of directional arrows will appear. Pay attention to their order before entering anything.
Step 4: Enter the Directions
Input each arrow exactly as displayed.
Step 5: Collect Your Sprite
Successfully completing the sequence will provide the corresponding Sprite reward.
One useful feature is that there is no time limit for entering the sequence. You can take a moment to make sure you've identified every direction before committing to the input.
What If You Enter the Wrong Direction?
Don't worry if you make a mistake.
Entering an incorrect direction simply causes the sequence to restart. The Cheat Code itself remains available, meaning you can attempt it again instead of losing the opportunity entirely.
This makes Cheat Codes fairly forgiving for players who are encountering the mechanic for the first time.
However, if you're completing one in an active area, spending too much time retrying can leave you vulnerable to opponents. That's where Cheat Master becomes particularly useful.
Cheat Master Sprite: The Fast Way to Complete Codes
The Cheat Master Sprite is one of the most useful tools for players who plan to interact with Cheat Codes frequently.
Without Cheat Master, you need to manually reproduce every directional input. With Cheat Master, the process can be automated.
After interacting with a Cheat Code, press a button and Cheat Master can enter the correct sequence automatically.
This can save considerable time when you're:
Searching for multiple Sprites
Looting quickly after landing
Playing in contested areas
Farming Cheat Codes during several matches
Trying to reduce repetitive manual inputs
If Sprite collection is part of your Chapter 7 Season 4 strategy, unlocking Cheat Master can make the entire process much more convenient.
Fortnite Cheat Code Rarity Guide
Cheat Codes come in different colors, with each color corresponding to a minimum Sprite rarity and a different number of required inputs.
Cheat Code Color Minimum Sprite Rarity Required Enters
Blue Rare 4
Purple Epic 5
Gold Legendary 6
Generally, higher-rarity Cheat Codes require more inputs but can provide better Sprite rewards.
The extra difficulty isn't particularly significant once you've become familiar with the mechanic, especially if you have Cheat Master available.
Are Cheat Code Spawns Guaranteed?
Although you may learn that certain areas are useful for finding Cheat Codes, their rarity is not fixed from match to match.
For example, discovering a Gold Cheat Code in a specific location doesn't mean you'll find another Gold version there during your next match.
The rarity is randomized for each match, so players shouldn't assume that a particular location guarantees a Rare, Epic, or Legendary code.
Learning where Cheat Codes can appear is still useful, but the reward level remains unpredictable.
Where Can You Find Cheat Codes?
Cheat Codes aren't limited to major named locations.
They can appear on:
Walls
Ground surfaces
Areas away from major POIs
Different parts of the Battle Royale island
Because of this, players should avoid checking only popular landing spots. Exploring less obvious areas can also lead to Cheat Code discoveries.
For players who want a more direct approach, the Cheat Code Locator can help.
How to Get a Cheat Code Locator
There are two ways to obtain a Cheat Code Locator.
The first option is through the Fortnite Override Lobby Hack admin panel.
The second option is to visit the Sprite Dust Services vendor at an Extraction Site and purchase the Locator for 1,500 Sprite Dust.
There is a daily restriction on this purchase, however. The vendor only allows players to buy one Cheat Code Locator per day.
Because of that limit, players who are actively farming Sprites should think carefully about when to use the Locator rather than spending it without a plan.
Tips for Finding Cheat Codes Faster
Pay Attention to Sound
Audio cues can reveal that a Cheat Code is nearby. Keep your sound awareness high while exploring.
Use Visual Sound Indicators
Visual sound effects can provide additional information about nearby interactive objects, particularly when visibility is limited.
Search Beyond POIs
Don't assume every Cheat Code will be inside a major named location. Check walls and ground surfaces throughout the island.
Study the Entire Sequence
Since there's no time limit, there's little reason to rush. Make sure you understand the complete sequence before entering it.
Take Advantage of Cheat Master
Once you've obtained Cheat Master, use its automatic input feature to reduce the amount of manual work required.
Don't Expect the Same Rarity Twice
A Gold Cheat Code found in one match doesn't guarantee another Gold code at the same location in your next game.
Does Fortnite V-Bucks Matter for This Feature?
Cheat Codes themselves are primarily part of the in-match Sprite system, so players don't need to spend Fortnite V-Bucks simply to complete a Cheat Code.
However, V-Bucks remain an important part of the wider Fortnite ecosystem. Players regularly use them for cosmetic items, Battle Pass-related content, and other eligible purchases.
If you're planning your Fortnite spending, z2u.com can also be one place to look for Fortnite V-Bucks options alongside your regular in-game purchases. Keeping your spending organized can help you separate cosmetic purchases from gameplay-focused activities such as exploring for Cheat Codes and collecting Sprites.
The key point is that Cheat Codes are earned through gameplay rather than simply purchasing your way through the mechanic.
Should You Farm Cheat Codes?
For players who want to collect as many useful Sprites as possible, learning the Cheat Code system is worthwhile.
The mechanic encourages exploration instead of relying exclusively on conventional loot sources. Since Cheat Codes can appear across different areas of the island and their rarity is randomized, every match can offer a slightly different experience.
Rare, Epic, and Legendary codes also give players a reason to keep searching, while Cheat Master makes repeated interactions significantly faster.
A good strategy is to combine careful exploration with audio awareness, use the Cheat Code Locator when appropriate, and prioritize obtaining Cheat Master if you plan to farm Sprites regularly.
Final Thoughts
Fortnite Cheat Codes add a fresh interactive layer to Chapter 7 Season 4's Sprite system.
The mechanic is simple once you understand it: locate a glowing code, select ENTER CHEAT, study the directional sequence, and enter it correctly to receive a Sprite.
The most important things to remember are:
Cheat Codes can appear on walls and the ground.
Audio and visual sound cues can help locate them.
There is no time limit for entering a sequence.
Incorrect inputs simply require you to restart.
Blue, Purple, and Gold codes correspond to Rare, Epic, and Legendary Sprite tiers.
Rarity is randomized between matches.
Cheat Code Locators can be obtained through the Override Lobby Hack system or purchased for 1,500 Sprite Dust.
The Sprite Dust Services vendor limits Locator purchases to one per day.
Cheat Master can automate the directional input process.
Once these mechanics become familiar, hunting Cheat Codes becomes much less complicated. Combine exploration with the right tools, and you'll be able to collect Sprites more efficiently throughout Fortnite Chapter 7 Season 4.
Blue Rare 4
Purple Epic 5
Gold Legendary 6
They can appear on:
Walls
Ground surfaces
Search Beyond POIs
Final Thoughts
