centrālā atslēga
sīpols
Ziņojumi: 20
Pievienojies: 16 Mar 2012, 21:46
Braucu ar: 316i
16 Mar 2012, 22:07
sveiciens visiem, pirmais posts forumā :bmw:
gribēju prasīt cik izmaksā komforta bloks un tā nomaiņa, vai to var izdarīt pats, vai tur kaut kas arī jāprogrammē ?
auto ir e36 316 kupeja, problēma - nestrādā centralka un el. logi :grrr:
gribu uzzināt izmaksas - iespējams pievienošos jūsu pulkam :hahaha:
16 Mar 2012, 22:34
'Man ir/bija līdzīga problēma.
Manā gadījumā atrisinājums- devos pie labi pazīstama elektriķa, tas man caur kompi norestartēja/pārprogrammēja logus un piekodē atslēgu!
Bloks pagaidām jāmaina nebija, bet tikai jāpārprog, konkrētās štelles!
Izmaksas ap 20ls!
Pieodēt atslēgu varam arī paši:
Older 3 Button Key (E36, E38, E39)
Remote Key Re-Initialise - If a key fails to operate remotely, it will have to be re-initialised (all keys in sequence at the same time)
1. Get in and close all doors
2. Turn the ignition on & off quickly (no more than 5 seconds) to start the process. Next action must take place within 30 seconds
3. First key - hold down button #2 (unlock - on the bottom left with the key blade pointing up) while striking button #1 (lock - the BMW logo) three times. Release button #2. This should be confirmed by door lock operation.
4. If you have more than 1 key then you need to repeat for the other keys within 30 seconds of first or they will be rendered inactive.
5. After last key then cycle the ignition on/off to finalise the process (it is not necessary to start the engine).
Both keys should now have new randomly selected security code words - assigned by the car's system.
Those codes will be continuously incremented within the new sequence each time you hit a button. It is when they get out of sequence with the car that they loose the capability to be recognised and you then have to do this again.
This occurs when you take longer than 1 minute changing the battery, or if you hit the buttons more than 1000 times when it is out of range of the car.
sīpols
Ziņojumi: 20
Braucu ar: 316i
05 Apr 2012, 16:35
kādam nav aizķērusies kompī kāda bilde no coupes centrālās bloka ?
vajadzētu tieši to augšu.
coupēm jau visi tie kõdi vienādi vai nē ? :rolleyes:
05 Apr 2012, 20:03
nee vienadi nau, ir vismaz divu dazadu veidu vinji, mok vairak
rokijs7777
Ziņojumi: 247
Pievienojies: 22 Apr 2012, 21:59
Braucu ar: Toyota Corolla
Atrašanās vieta: Jugla, Ādaži
24 Apr 2012, 20:17
lieta tāda:
centrālā atslēga joko ... slēdzu ciet... aizslēdzas - sekunde - viss atslēdzas vaļā....
dzīt uz šrotu? :giggle:
Agris
Ziņojumi: 2665
Braucu ar: 325
24 Apr 2012, 21:12
varbūt ar! bet vispār palasi elekntronikas topikus par centralu. ir jau runāts! vadu vai sleedziishu vaina.
24 Apr 2012, 21:19
rokijs7777 rakstīja:lieta tāda:
AR tālvadīu no atslēgas?
rokijs7777
Ziņojumi: 247
24 Apr 2012, 21:28
no atslēgas
24 Apr 2012, 21:54
Mēģini pārkodēt!
Palasi postu, kaut kur jau pieminēju kā to darīt!
STUDENTS
Ziņojumi: 1701
Pievienojies: 07 Mar 2012, 13:12
Braucu ar: Baltu bembi
25 Apr 2012, 15:00
Ir tāda problēma, ka kopš nomainiju bagažnieka vāku savam mobīlim.. man vairs centrālā nereaģē uz bagažnieku.. respektīvi aizslēdzot auto - bagažnieks neaizslēdzas...
Kur meklēt problēmu? Kādi varianti? kpc tā? :gigigi:
25 Apr 2012, 18:07
Liekas, ka grabažniekam zem abšivkas pie slēdzenes ir vadi gan gaismai un arī,iespējams kontakti centrālajai!
Visu savienoji?
25 Apr 2012, 20:45
STUDENTS rakstīja:Ir tāda problēma, ka kopš nomainiju bagažnieka vāku savam mobīlim.. man vairs centrālā nereaģē uz bagažnieku.. respektīvi aizslēdzot auto - bagažnieks neaizslēdzas...
jaa, ka jau erda teica ir japarliecinas ka vadi pieslegti, ka pats motoritis stradaa, iespejams izkabinajies kads no stiesnisiem.
saac ar vienkarsajam lietam pirms keries pie vadu izzvanisanas ;)
Articimo
Ziņojumi: 38
Pievienojies: 04 Feb 2012, 13:07
25 Apr 2012, 21:59
Man arī ir problēma ar centrālo.
Nospiežot pogas viss darbojas(iemirgojas pagriezieni utt) , bet durvis neslēdzas ciet.
Drošinātāji visi kārtībā. Ar atslēgu nevar aizslēgt, jo tur jau no iegādes brīža ir problēma ar slēdzeni(vadītāja pusē), nolauzta ķepiņa kur ielikt to stienīti. Viņām tak vajadzētu tāpat aizslēgties vai ne? Kur lai meklē problēmu?
kadrs
Ziņojumi: 165
Pievienojies: 31 Okt 2011, 10:59
26 Apr 2012, 23:17
Ir problēma ar centrālo. Slēdzu ar atslēgu, bet pasažieru pusē aizmugurējās durvis neaizslēdzas, vai arī ja slēdzu mašīnu vaļā tad tās durvis neatslēdzas. Ar roku tās durvis mierīgi var slēgāt ciet un vaļā. Kā lai zinu kur meklēt vainu un noskaidroju kas tieši pie vainas?
djjys
Ziņojumi: 616
Pievienojies: 21 Okt 2011, 22:39
Braucu ar: Atejvaku
28 Apr 2012, 02:53
man maza kibele ar centralo atslegu. sledzot durvis ciet ar atslegu pagriezot vienreiz aizsledzas visas durvis un atsledzas atkal valja, pagriezot otro reizi aizsledzas pavisam, sledzot valja prieksejas abas un viena aizmugureja atsledzas viena paliek aizslegta. ar signalizacjiju ir ta ka nospiezot pogu aizsledzas atsledzas otreiz nospiezot tikai nokauc signalizacija un treso reiz nospiezot aizsledzas, kur aptuveni vainu mekleet? varbut tanis durvis kuras neatsledzas pashas??? :doh:
Agris
Ziņojumi: 2665
Braucu ar: 325
28 Apr 2012, 10:22
domajau ka jaa. sāc ar tām kas neaizsleedzas. jo parasti durvis neaizsleedzas, ja kaadas palikušas vaļā! automa'tiski atmet visas vaļā.
djjys
Ziņojumi: 616
Braucu ar: Atejvaku
28 Apr 2012, 10:43
shorit skatijos itka visi mehanismi viegli strada un nekadu problemu nav tikai ta slegashanas nepatiik!!!
Liss
Ziņojumi: 2562
Braucu ar: turbo bamsli
Reputācija: 40
28 Apr 2012, 20:31
Slēdzot ciet vēro vai visi "pipši" aiztaisas vienlaicīgi.
Man kaut kas līdzīgs bija, kad bagāžnieka centrālās atslēgas modulī mikrolēdzis safisās - rādīja kompim, ka ir atslēgtā pozīcijā visu laiku. Tikai man vienmēr, kad aizslēdza, tad atslēdzās.
djjys
Ziņojumi: 616
Braucu ar: Atejvaku
29 Apr 2012, 11:47
Itka vis normali shodien atklaju to ka bagaznieks vispar neaizsledzas. bus japaskatas kas lacitim vedera!!! :lol:
29 Apr 2012, 19:06
nonemot apsifku vaakam, tur visam tiek klat, iespejams ka vados bus problemna, bet to jau manis kad nonemsi apsuvumu, ja tur viss labi, izzvani vadus
