RSorder OSRS: How to Defeat Jad
Stellaol
Ziņojumi: 3
Pievienojies: 17 Okt 2025, 09:44
17 Okt 2025, 09:49
The Fire Cape is one of the most iconic achievements in Old School RuneScape (OSRS). To earn it, players must survive the TzHaar Fight Cave-a gauntlet of 63 waves ending with the infamous boss, TzTok-Jad. This guide covers the best gear, inventory setup, safe spots, wave strategies, and a step-by-step breakdown of how to RuneScape gold finally take down Jad.
Essential Requirements
The most important prerequisite for the Fight Caves is 43 Prayer, unlocking all protection prayers. Technically, 40 Prayer is enough for Protect from Missiles and Protect from Magic, but 43 ensures you are safe from melee monsters inside the caves.
While it is possible to attempt with melee or magic, Ranged is the recommended combat style. At a minimum, you'll want 61 Ranged for a Rune Crossbow, though 75 Ranged is highly recommended for the Toxic Blowpipe, which dramatically increases your odds of success. Having enough RuneScape gold can also help you succeed.
Best Gear Setup
Weapons
Toxic Blowpipe (with amethyst or better darts) - Best for your first Fire Cape.
Crossbow - Crucial for long-range tagging and luring healers. Use enchanted diamond bolts for high-damage procs.
Top choices: Zaryte Crossbow, Armadyl Crossbow, Dragon Crossbow (budget), Rune Crossbow (entry-level).
Armor
Prioritize Ranged attack bonus and defensive stats:
Best-in-slot: Masori or Armadyl (if affordable).
Practical options: Karil's or Black/Red Dragonhide.
At 70 Ranged, Hallowed Crystalhide armor or Blessed Dragonhide offers strong prayer bonuses and magic defense.
Accessories
Necklace: Necklace of Anguish > Amulet of Fury > Amulet of Glory.
Shield slot (if using a crossbow): Blessed Dragonhide Shield > Dragonhide Shield > Armadyl book.
Ring: Ring of Suffering (best for learners), Archer's Ring, or Brimstone Ring (budget).
Inventory Setup
Bring:
10-12 Saradomin Brews
12 Super Restores
2 Bastion Potions (for Ranged boosts)
Stamina potion or Purple Sweets (for run energy management)
Optional: Saradomin Godsword (75 Attack) for healing with the special attack
Fight Cave Monsters
Across 63 waves, you'll face seven enemy types:
Tz-Kih (Bats) - Drain Prayer on hit, even if they hit zero. Kill quickly.
Tz-Kek (Blobs) - Split into two small forms when killed.
Tok-Xil (Rangers) - Max hit 13, highly accurate. Use Protect from Missiles.
Yt-MejKot (Melee monsters) - Max hit 25, can heal themselves and others. Safe spot or pray melee.
Ket-Zek (Mages) - Max hit 54 with magic, also deals strong melee if close. Always Protect from Magic.
TzTok-Jad (Wave 63) - The final boss, hitting up to 97. Switch between Protect from Missiles and Protect from Magic.
Yt-HurKot (Healers) - Spawn when Jad reaches 50% health, healing him until distracted or killed.
Safe Spots
The most reliable safe spot is Italy Rock, a formation in the middle of the cave shaped like the country of Italy. It's used to trap melee enemies while you safely deal with rangers, mages, and bats. Other protrusions around the cave can also serve as temporary safe spots.
Wave Strategies
Early waves - Stand at Italy Rock and kill bats at a distance to prevent Prayer drain. Safe spot blobs when possible.
Wave 7 - Rangers begin to appear. Always pre-activate Protect from Missiles at the end of wave six.
Wave 15 - First melee monster arrives. Use Italy Rock to trap it while focusing on Rangers.
Wave 31 - First mage spawns. Always Protect from Magic, and never get into melee range.
Wave 52 - A ranger and mage spawn together. Stay on Protect from Magic and prioritize killing the ranger.
Wave 62 - The final wave before Jad. Set your crossbow to long range, position yourself near Jad's spawn point (revealed by the spawn of the last mage), but don't stand too close.
How to Defeat Jad
Jad alternates between Ranged and Magic attacks:
Magic attack: Stands on back legs, hurls a fireball.
Ranged attack: Quick stomp.
The key is to react to his animations and swap your protection prayers accordingly. You have a couple of seconds to switch-don't panic and swap too quickly.
At 50% health, Jad spawns four healers. They must be distracted or killed:
Switch to your crossbow for long range.
Tag each healer one by one, pulling them off Jad.
Keep focus on prayer switching-Jad remains the main threat.
If healers are lured correctly, you can safely finish off Jad. Beware: if Jad heals back to buy OSRS gold full and the healers are killed, they will respawn.
