Restavret Gofra
Is there any way to check this out , or I simply have to replace it and hope that result will be positive :) ?
Also when I remove the oil dip stick I hear some bubbleing which I guess is normal , or this is sign for damaged CCV ?
Maybe this topic will help somehow :) http://www.bimmerfest.com/forums/showth ... p?t=536317
Well this is very useful link, thanx!
Actually I have some oil leak both from the Valve cover gasket and from the engines front low side where is the engines chain , and a bit around the oil filter body.
According the theory is means that the CCV i slightly open at idle which cause erratic idle , right?
Also , form the last check up (tehniksa apskate) i see the following parameters:
CO (%): 0.5
CO paaugst. (%): 0
HC (pmm)): 150
HC = 150 may be indicates a fuel trim or rich mixture?
CO (%): 0.5
CO paaugst. (%): 0
HC (pmm)): 150
There's something about fuel trim: http://wiki.ross-tech.com/wiki/index.php/Fuel_Trim_Info
In my first check up this year (m40) i had HC about 160, but that was because i had huge holes in my muffler
Changed the muffler and now have 102. And also i haven't heard, that a little bit wrong fuel trim has affected iddling.
Not 101% sure, but if i got all the stuff about this ccv right, than yes.
gofru jaliek tikai original un jaunuivoka1981 rakstīja:Un cik ilgi ta jauna turesi ?
original manksa 30ls , vai zinat avi kaut kur varetu dabut to letak ?
Paldies!
