BMW Race Car Build for $900
Congrats with daughter!
Thumbs up for project
Can I ask, how did you find out about e36.lv?
Thank You So Much!!! I'm really excited. And she's really a good baby too. Sleeping all Night!māriņš rakstīja:Congrats with daughter!
Thanks, As for your forum. Googled E36, Saw the cars posted here and created an account.Edvards77 rakstīja:Thumbs up for projectCan I ask, how did you find out about e36.lv?
Hey Everyone,....We're BACK !!!
Isn't the strut brace supposed to be put on when the front struts are unloaded?
Why?JorensHS rakstīja:Isn't the strut brace supposed to be put on when the front struts are unloaded?
So that when you put it down tension is placed on it and it becomes a load bearing structuremāriņš rakstīja:Why?JorensHS rakstīja:Isn't the strut brace supposed to be put on when the front struts are unloaded?
nemiz, atstaite lien virsu gan uz nepacelta gan pacelta auto. un neiet runa par regulejamam. no ta var izspriest ka stavot uz vietas tas glazes nenostaiga. uz bedrem gan
For non-adjustable ones it does not matter..JorensHS rakstīja:So that when you put it down tension is placed on it and it becomes a load bearing structuremāriņš rakstīja:Why?JorensHS rakstīja:Isn't the strut brace supposed to be put on when the front struts are unloaded?
e30 S50B30us
e90 M57TU2D30
e90 M57TU2D30
That`s right.ch. rakstīja:For non-adjustable ones it does not matter..
New Video for you Guys !!!
Your biggest problem is suspention, its to soft and when u tray sliding and make bouth weels spin, all wheight get one one side and its about 60% mor harder to make clean slide and bouth weels spin. Make sum upgarads to read and front suspention, for begining u can try some buget coilovers, they are note very good, but they make your care more stiffer.millertimebmw rakstīja:New Video for you Guys !!!![]()
And dont forget, make your car lower, it changes center off mass hight and car will be more balanced. and u may try lower profile tires, there u will get more stability to.
Good luck with your project
That 240sx thouh
I know, crazy. I thought he was dead when I saw the car... So happy he was ok.māriņš rakstīja:That 240sx thouh
I think you need change engine oil after this practice.
An yeah body roll is huge. Need atleast stifer springs.
If you pump more psi in rear tires it would slide easier. :)
māriņš rakstīja:I think you need change engine oil after this practice.
I think you might be right, haha. It is going to be like 100% black. And 100psi for the rear tires will work
Lācis rakstīja:Your biggest problem is suspention, its to soft and when u tray sliding and make bouth weels spin, all wheight get one one side and its about 60% mor harder to make clean slide and bouth weels spin. Make sum upgarads to read and front suspention, for begining u can try some buget coilovers, they are note very good, but they make your care more stiffer.millertimebmw rakstīja:New Video for you Guys !!!![]()
he he baigais jokdaris, atri rakstos pieļāvas vairākas kļūdas zinu.Balcers rakstīja:Lācis rakstīja:Your biggest problem is suspention, its to soft and when u tray sliding and make bouth weels spin, all wheight get one one side and its about 60% mor harder to make clean slide and bouth weels spin. Make sum upgarads to read and front suspention, for begining u can try some buget coilovers, they are note very good, but they make your care more stiffer.millertimebmw rakstīja:New Video for you Guys !!!![]()
Good luck with your projectjāiet politikā ar angļu valodu
I hope you enjoy the new season!
