E36-aivis328 e36 un citi zveri
GatisB.
Ziņojumi: 1031
Braucu ar: 2
Tik tas pelēkais salons :rolleyes: , bet vismaz aizmugurē dalītais sēdeklis.
aivis328
Ziņojumi: 1651
Braucu ar: F32 425d
Ja salons galigi nepareiza krasa varbut sanaks atrast melnu bet tad jau redzes
Instagram INDIGAIS
Ar intresi sekošu šitam topikam :super: tāds riktīgi klasisks BMW.
Ir kādas krāsu domas jau ?
aivis328
Ziņojumi: 1651
Braucu ar: F32 425d
Gribetos jau parkrasot melnu bet lai saglabatu oem vertibu laikam bus japaliek pie sarkanas :(
Instagram INDIGAIS
melns nebutu tas
vai nu violets vai sarkans butu :super:
aivis328
Ziņojumi: 1651
Braucu ar: F32 425d
buss jau vien jaatsta sarkans tikkai tapec ka oem ir tada krasa
bet taa vispar man nepatik sarka krasa pluss vel tapec ka vinja izbalee :doh:
ja gadijauma kads zin kur var dabut oem diskus turbinas prieks m5 tad dod man zinju :hahaha:
Instagram INDIGAIS
Lawwr
vis jau skaisti un forši, tik žēl, ka visiem stūre bardačokā. :rolleyes:
aivis328
Ziņojumi: 1651
Braucu ar: F32 425d
te buss vairak detalizetas bildes no iepriekseja saimnieka topika
so auto vairak varetu saukt par Barn find :lol:
[/quote]
Pēdējais labojis aivis328 - 20 Okt 2014, 22:49, kopā labots 1 reizi.
Instagram INDIGAIS
aivis328
Ziņojumi: 1651
Braucu ar: F32 425d
Exhaust hangers are all original :tounge:
This is going to cost a small fortune :sad:
And front, have this cover sorted for about 15euro and got the other side too seems to have had a minor tip here on driver side and tow bar is slightly bent
Fair bit of leakage about the underside from anything with oil.
Front sills on e34's always go, nothing new here an no surprise..
Jacking point, worst one
The areas that always go even on good cars, you can see the fooking screw someone used to hold the sill in place on both sides :@
Sills in general further back, all seems good but wont know until the skirts are off very hard to tell
Arches, some have rust some don't, again not bad for the age of the car
Fronts being the worst as usual..
This door needs replacing, beyond repair and in bad shape
This is the rear bit of damage from underneath
Scorpion cat back
Lines
Rear arches are fine on both side
Pēdējais labojis aivis328 - 20 Okt 2014, 22:51, kopā labots 1 reizi.
Instagram INDIGAIS
armis
Ziņojumi: 1241
Braucu ar: baklažāna dvuļu
10 Okt 2014, 09:00
Kaplis labs :clap: Tikai nedaudz prasās sakopt :hahaha: Tas ka krāsa ir izbalējusi ir tikai normāli sarkanai krāsai (nezinu kapēc bet visvairāk izbalē tieši sarkanās krāsas)
A_C
Ziņojumi: 551
Pievienojies: 19 Feb 2014, 17:58
10 Okt 2014, 09:54
Baigais rūsas kamols :D
Domā tā pa kārtīgo būvēt?
Inuta
Ziņojumi: 395
Pievienojies: 04 Mar 2013, 13:49
Braucu ar: darba auto
10 Okt 2014, 10:49
Darba daaaaudz,bet gala rezultats varetu būt skaists :bmw:
Rolish
Ziņojumi: 715
Braucu ar: old wagon
10 Okt 2014, 11:03
Laaabs. Tik krāso hellrot red ,būs daudz labāk !
kkk_24
Ziņojumi: 724
Atrašanās vieta: Tukums/Rīga
10 Okt 2014, 12:07
hellrot red :gigigi:
rot = sarkans
izskatās jau nabags padzīvojis, bet interesanti, interesanti... motors 3.6 vai 3.8?
GatisB.
Ziņojumi: 1031
Braucu ar: 2
10 Okt 2014, 12:17
s38b36, s38b38 eļļas korķis atrodas citur.
aivis328
Ziņojumi: 1651
Braucu ar: F32 425d
10 Okt 2014, 13:59
GatisB. rakstīja:s38b36, s38b38 eļļas korķis atrodas citur.
Tu esi parliecinats ko? Ja jau zini tik labi tad kurs motors ir mans? :D
Sis ir s38b36 kas orginali nak 90 gada modelim
Instagram INDIGAIS
Rolish
Ziņojumi: 715
10 Okt 2014, 14:03
kkk_24 rakstīja:hellrot red :gigigi:
rot = sarkans
ā,paldies par info ,nezināju :lol:
a tad montrealBLAU - blau ir zils ārī ?
Cik šāds M5 maksā in UK ? jāsāk krāt moška :hahaha:
kkk_24
Ziņojumi: 724
10 Okt 2014, 14:11
blau=zils
pirmajās bildēs ir striķī- vispār ir ejošs? Motors bildēs izskatās tikpat bēdīgs cik krāsojums..
aivis328
Ziņojumi: 1651
Braucu ar: F32 425d
10 Okt 2014, 14:21
Cenas visadas skatoties pec stavoklja no 2500-17000€
Uz so bridi nelec jo signalizacija atteikusies
Motora tik no arpuses tada netirs bet ta vispar ir ljoti labs un tadelj tik njemu ka motors labs parejo sataisit nav prob
Noskrejis tik 177k kilometri ;)
Instagram INDIGAIS
10 Okt 2014, 16:23
Nekad nav simpatisejushi e34
Un shis nabags izskatas ka ir ellei gajis cauri
Saimnieks vinju nav zhelojis.bet dzinejs,esmu dzirdejis ka shie sot ljoti izturigi
