E36 tehniskā specifikācija
31 Dec 2012, 16:59
Avots : http://www.ultimatespecs.com/car-specs/BMW
316i (1991-1993)
Engine type - Number of cylinders : I 4
Engine Code : M40B16
Fuel type : Petrol
Fuel System : Bosch DME M1.7
Engine Alignment : Longitudinal
Drive wheels - Traction - Drivetrain : RWD
Engine size - Displacement - Engine capacity : 1596 cm3 ( 97.4 cu-in )
Bore x Stroke : 72 x 84 mm ( 2.83 x 3.31 inches)
Number of valves : 8 Valves
Aspiration : N/A
Compression Ratio : 9
Maximum power - Output - Horsepower : 100 PS (99 bhp) (74 kW) @ 5500 rpm
Maximum torque : 141 Nm (103 lb.ft) @ 4250 rpm
Transmission Gearbox - Number of speeds : 5 speed Manual
BMW E36 3 Series Sedan 316i Dimensions, Aerodynamics and Weight
Wheelbase : 270 cm ( 106.3 inches )
Length : 443.3 cm ( 174.53 inches )
Width : 169.8 cm ( 66.85 inches )
Height : 139.3 cm ( 54.84 inches )
Aerodynamic drag coefficient - Cx :
Front Brakes - Disc dimensions : Discs (286 mm)
Rear Brakes - Dics dimensions : Drums (228 mm)
Front Tyres - Rims dimensions : 185/65 R15
Rear Tyres - Rims dimensions : 185/65 R15
Kerb Weight : 1190 kg ( 2624 lbs )
Weight-Power Output Ratio : 11.9 kg/cv
Trunk capacity : 435 L
Front Suspension : McPherson struts
Rear Suspension : Multi-Link Z-Axle
BMW E36 3 Series Sedan 316i Performance
Top Speed : 191 km/h (118 Mph)
Acceleration 0 to 100 km/h (0 to 62 mph) : 13.1 s
Acceleration 0 to 400m (1/4 mile) : s
Acceleration 0 to 1000m : 34.1 s
BMW E36 3 Series Sedan 316i Consumptions, Emissions and Range
Fuel Consumption - Economy - Efficiency* : 6.1L / 7.5L / 10.2L / -L
Range : km
Fuel Tank Capacity : 65 L
CO2 emissions : g/Km
____________________________________________________________________________________________
316i (1993-1998)
Engine Code : M43B16
Fuel type : Petrol
Fuel System : Bosch DME M1.7.1
Bore x Stroke : 84 x 72 mm ( 3.31 x 2.83 inches)
Aspiration : N/A
Compression Ratio : 9.7
Maximum power - Output - Horsepower : 102 PS (101 bhp) (75 kW) @ 5500 rpm
Maximum torque : 150 Nm (110 lb.ft) @ 3900 rpm
Weight-Power Output Ratio : 11.7 kg/cv
Top Speed : 195 km/h (121 Mph)
Acceleration 0 to 100 km/h (0 to 62 mph) : 12.7 s
Acceleration 0 to 1000m : 33.8 s
Fuel Consumption - Economy - Efficiency* : 5.6L / 7.3L / 9.4L / -L
Range : km
_______________________________________________________________________________________________
318i (1991-1993)
Engine Code : M40B18
Fuel type : Petrol
Engine size - Displacement - Engine capacity : 1796 cm3 ( 109.6 cu-in )
Bore x Stroke : 81 x 84 mm ( 3.19 x 3.31 inches)
Aspiration : N/A
Compression Ratio : 8.8
Maximum power - Output - Horsepower : 113 PS (111 bhp) (83 kW) @ 5500 rpm
Maximum torque : 162 Nm (119 lb.ft) @ 4250 rpm
BMW E36 3 Series Sedan 318i Dimensions, Aerodynamics and Weight
Kerb Weight : 1205 kg ( 2657 lbs )
Weight-Power Output Ratio : 10.7 kg/cv
BMW E36 3 Series Sedan 318i Performance
Top Speed : 198 km/h (123 Mph)
Acceleration 0 to 100 km/h (0 to 62 mph) : 11.5 s
Acceleration 0 to 1000m : 32.6 s
BMW E36 3 Series Sedan 318i Consumptions, Emissions and Range
Fuel Consumption - Economy - Efficiency* : 6.4L / 7.8L / 10.6L / -L
Range : km
318i (1993-1998)
Engine Code : M43B18
Fuel type : Petrol
Bore x Stroke : 84 x 81 mm ( 3.31 x 3.19 inches)
Aspiration : N/A
Maximum power - Output - Horsepower : 115 PS (113 bhp) (85 kW) @ 5500 rpm
Maximum torque : 168 Nm (123 lb.ft) @ 3900 rpm
Weight-Power Output Ratio : 10.5 kg/cv
Top Speed : 201 km/h (124 Mph)
Acceleration 0 to 100 km/h (0 to 62 mph) : 11.3 s
Acceleration 0 to 1000m : 32.4 s
Fuel Consumption - Economy - Efficiency* : 5.7L / 7.4L / 9.6L / -L
Range : km
318 is (1992-1996)
Engine Code : M42B18
Fuel type : Petrol
Number of valves : 16 Valves
Aspiration : N/A
Compression Ratio : 10
Maximum power - Output - Horsepower : 140 PS (138 bhp) (103 kW) @ 6000 rpm
Maximum torque : 175 Nm (129 lb.ft) @ 4500 rpm
BMW E36 3 Series Sedan 318iS Dimensions, Aerodynamics and Weight
Front Brakes - Disc dimensions : Vented Discs (286 mm)
Rear Brakes - Dics dimensions : Discs (280 mm)
Front Tyres - Rims dimensions : 195/65 R14
Rear Tyres - Rims dimensions : 195/65 R14
Kerb Weight : 1240 kg ( 2734 lbs )
Weight-Power Output Ratio : 8.9 kg/cv
BMW E36 3 Series Sedan 318iS Performance
Top Speed : 213 km/h (132 Mph)
Acceleration 0 to 100 km/h (0 to 62 mph) : 10.2 s
Acceleration 0 to 1000m : 31.1 s
BMW E36 3 Series Sedan 318iS Consumptions, Emissions and Range
Fuel Consumption - Economy - Efficiency* : 6.4L / 7.7L / 10.9L / -L
Range : km
________________________________________________________________________________________________
320i (1991-1994)
Engine type - Number of cylinders : I 6
Engine Code : M50B20
Fuel type : Petrol
Fuel System : Siemens DME MS41
Engine size - Displacement - Engine capacity : 1991 cm3 ( 121.5 cu-in )
Bore x Stroke : 80 x 66 mm ( 3.15 x 2.6 inches)
Number of valves : 24 Valves
Aspiration : N/A
Compression Ratio : 11
Maximum power - Output - Horsepower : 150 PS (148 bhp) (110 kW) @ 5900 rpm
Maximum torque : 190 Nm (140 lb.ft) @ 4700 rpm
BMW E36 3 Series Sedan 320i Dimensions, Aerodynamics and Weight
Kerb Weight : 1315 kg ( 2899 lbs )
Weight-Power Output Ratio : 8.8 kg/cv
BMW E36 3 Series Sedan 320i Performance
Top Speed : 214 km/h (133 Mph)
Acceleration 0 to 100 km/h (0 to 62 mph) : 10.0 s
Acceleration 0 to 1000m : 30.9 s
BMW E36 3 Series Sedan 320i Consumptions, Emissions and Range
Fuel Consumption - Economy - Efficiency* : 7.1L / 8.7L / 12.8L / -L
Range : km
320i (1994-1998)
Engine Code : M52B20
Fuel type : Petrol
Fuel System : Siemens DME MS41.0
Aspiration : N/A
Maximum torque : 190 Nm (140 lb.ft) @ 4200 rpm
Front Tyres - Rims dimensions : 205/60 R15
Rear Tyres - Rims dimensions : 205/60 R15
Kerb Weight : 1375 kg ( 3031 lbs )
Weight-Power Output Ratio : 9.17 kg/cv
Acceleration 0 to 100 km/h (0 to 62 mph) : 9.9 s
Acceleration 0 to 1000m : 30.7 s
Fuel Consumption - Economy - Efficiency* : 6.8L / 8.3L / 11.4L / -L
Range : km
Fuel Tank Capacity : 62 L
323i (1995-1998)
Engine Code : M52B25
Fuel type : Petrol
Engine size - Displacement - Engine capacity : 2449 cm3 ( 149.4 cu-in )
Bore x Stroke : 84 x 75 mm ( 3.31 x 2.95 inches)
Aspiration : N/A
Compression Ratio : 10.5
Maximum power - Output - Horsepower : 170 PS (168 bhp) (125 kW) @ 5500 rpm
Maximum torque : 245 Nm (180 lb.ft) @ 3950 rpm
BMW E36 3 Series Sedan 323i Dimensions, Aerodynamics and Weight
Rear Brakes - Dics dimensions : Vented Discs (275 mm)
Kerb Weight : 1385 kg ( 3053 lbs )
Weight-Power Output Ratio : 8.15 kg/cv
BMW E36 3 Series Sedan 323i Performance
Top Speed : 227 km/h (141 Mph)
Acceleration 0 to 100 km/h (0 to 62 mph) : 8.0 s
Acceleration 0 to 1000m : 28.9 s
BMW E36 3 Series Sedan 323i Consumptions, Emissions and Range
Fuel Consumption - Economy - Efficiency* : 6.7L / L / 12.9L / 9L (26 mpg)
Range : 688 km
CO2 emissions : 209 g/Km
325i (1991- )
Engine Code : M50B25
Fuel type : Petrol
Fuel System : Bosch DME M3.1
Engine size - Displacement - Engine capacity : 2494 cm3 ( 152.2 cu-in )
Aspiration : N/A
Maximum power - Output - Horsepower : 192 PS (189 bhp) (141 kW) @ 5900 rpm
Maximum torque : 245 Nm (180 lb.ft) @ 4700 rpm
BMW E36 3 Series Sedan 325i Dimensions, Aerodynamics and Weight
Kerb Weight : 1330 kg ( 2932 lbs )
Weight-Power Output Ratio : 6.9 kg/cv
BMW E36 3 Series Sedan 325i Performance
Top Speed : 233 km/h (144 Mph)
Acceleration 0 to 1000m : 28.4 s
BMW E36 3 Series Sedan 325i Consumptions, Emissions and Range
Fuel Consumption - Economy - Efficiency* : 7.0L / 8.4L / 13.2L / -L
Range : km
328i (1995-1998)
Engine Code : M52B28
Fuel type : Petrol
Engine size - Displacement - Engine capacity : 2793 cm3 ( 170.4 cu-in )
Bore x Stroke : 84 x 84 mm ( 3.31 x 3.31 inches)
Aspiration : N/A
Compression Ratio : 10.2
Maximum power - Output - Horsepower : 193 PS (190 bhp) (142 kW) @ 5300 rpm
Maximum torque : 280 Nm (206 lb.ft) @ 3950 rpm
BMW E36 3 Series Sedan 328i Dimensions, Aerodynamics and Weight
Kerb Weight : 1440 kg ( 3175 lbs )
Weight-Power Output Ratio : 7.46 kg/cv
BMW E36 3 Series Sedan 328i Performance
Top Speed : 236 km/h (146 Mph)
Acceleration 0 to 100 km/h (0 to 62 mph) : 7.3 s
Acceleration 0 to 1000m : 28 s
BMW E36 3 Series Sedan 328i Consumptions, Emissions and Range
Fuel Consumption - Economy - Efficiency* : 6.2L / 7.8L / 11.6L / -L
Range : km
316i COMPACT (1994-1999)
Fuel type : Petrol
Aspiration : N/A
BMW E36 3 Series Compact 316i Dimensions, Aerodynamics and Weight
Length : 421 cm ( 165.75 inches )
Height : 137.8 cm ( 54.25 inches )
Rear Brakes - Dics dimensions : Drums (229 mm)
Kerb Weight : 1215 kg ( 2679 lbs )
Trunk capacity : 300 L
Rear Suspension : Semi-trailing arm
BMW E36 3 Series Compact 316i Performance
Top Speed : 188 km/h (116 Mph)
Acceleration 0 to 100 km/h (0 to 62 mph) : 12.3 s
Acceleration 0 to 1000m : s
BMW E36 3 Series Compact 316i Consumptions, Emissions and Range
Fuel Consumption - Economy - Efficiency* : 5.7L / 7.5L / 9.1L / -L
Range : km
Fuel Tank Capacity : 52 L
318ti COMPACT (1994-1996)
Engine Code : M42 B18
Fuel type : Petrol
Aspiration : N/A
BMW E36 3 Series Compact 318ti Dimensions, Aerodynamics and Weight
Rear Brakes - Dics dimensions : Discs (272 mm)
Kerb Weight : 1255 kg ( 2767 lbs )
Weight-Power Output Ratio : 9.0 kg/cv
BMW E36 3 Series Compact 318ti Performance
Top Speed : 209 km/h (129 Mph)
BMW E36 3 Series Compact 318ti Consumptions, Emissions and Range
Fuel Consumption - Economy - Efficiency* : 6.5L / 7.9L / 10.6L / -L
Range : km
318tds COMPACT (1995-2001)
Engine Code : M41D17
Fuel type : Diesel
Fuel System : Bosch VP20
Engine size - Displacement - Engine capacity : 1665 cm3 ( 101.6 cu-in )
Bore x Stroke : 80 x 82.8 mm ( 3.15 x 3.23 inches)
Aspiration : Turbo
Compression Ratio : 22
Maximum power - Output - Horsepower : 90 PS (89 bhp) (66 kW) @ 4400 rpm
Maximum torque : 190 Nm (140 lb.ft) @ 2000 rpm
BMW E36 3 Series Compact 318 tds Dimensions, Aerodynamics and Weight
Kerb Weight : 1195 kg ( 2635 lbs )
Weight-Power Output Ratio : 13.3 kg/cv
BMW E36 3 Series Compact 318 tds Performance
Top Speed : 175 km/h (108 Mph)
Acceleration 0 to 100 km/h (0 to 62 mph) : 13.9 s
BMW E36 3 Series Compact 318 tds Consumptions, Emissions and Range
Fuel Consumption - Economy - Efficiency* : 4.4L / 6.0L / 7.4L / -L
Range : km
CO2 emissions : 168 g/Km
M3 COUP (1992-1995)
Engine Code : S50B30
Fuel type : Petrol
Engine size - Displacement - Engine capacity : 2990 cm3 ( 182.5 cu-in )
Bore x Stroke : 86 x 85.8 mm ( 3.39 x 3.35 inches)
Aspiration : N/A
Compression Ratio : 10.8
Maximum power - Output - Horsepower : 286 PS (282 bhp) (210 kW) @ 7000 rpm
Maximum torque : 320 Nm (236 lb.ft) @ 3600 rpm
BMW E36 3 Series Coupe M3 Dimensions, Aerodynamics and Weight
Width : 171 cm ( 67.32 inches )
Height : 133.5 cm ( 52.56 inches )
Aerodynamic drag coefficient - Cx : 0.32
Front Brakes - Disc dimensions : Vented Discs (315 mm)
Rear Brakes - Dics dimensions : Vented Discs (312 mm)
Front Tyres - Rims dimensions : 235/40 R17
Rear Tyres - Rims dimensions : 235/40 R17
Kerb Weight : 1460 kg ( 3219 lbs )
Weight-Power Output Ratio : 5.1 kg/cv
Trunk capacity : 405 L
BMW E36 3 Series Coupe M3 Performance
Top Speed : 250 km/h (155 Mph)
Acceleration 0 to 100 km/h (0 to 62 mph) : 6.0 s
Acceleration 0 to 1000m : 25.4 s
BMW E36 3 Series Coupe M3 Consumptions, Emissions and Range
Fuel Consumption - Economy - Efficiency* : 6.5L / 7.9L / 13.0L / 9.1L (25 mpg)
Range : 714 km
CO2 emissions : 212 g/Km
M3 EVO COUP (1996-1999)
Engine Code : S50B32
Fuel type : Petrol
Engine size - Displacement - Engine capacity : 3201 cm3 ( 195.3 cu-in )
Bore x Stroke : 86.4 x 91 mm ( 3.39 x 3.58 inches)
Aspiration : N/A
Compression Ratio : 11.3
Maximum power - Output - Horsepower : 321 PS (317 bhp) (236 kW) @ 7400 rpm
Maximum torque : 350 Nm (258 lb.ft) @ 3250 rpm
Transmission Gearbox - Number of speeds : 6 speed Manual
BMW E36 3 Series Coupe M3 Evo Dimensions, Aerodynamics and Weight
Wheelbase : 271 cm ( 106.69 inches )
Front Tyres - Rims dimensions : 225/45 R17
Rear Tyres - Rims dimensions : 245/40 R17
Kerb Weight : 1535 kg ( 3384 lbs )
Weight-Power Output Ratio : 4.78 kg/cv
Front Suspension : McPherson Struts
BMW E36 3 Series Coupe M3 Evo Performance
Acceleration 0 to 100 km/h (0 to 62 mph) : 5.5 s
Acceleration 0 to 1000m : 24.7 s
BMW E36 3 Series Coupe M3 Evo Consumptions, Emissions and Range
Fuel Consumption - Economy - Efficiency* : 6.0L / 7.3L / 13.0L / 11L (21 mpg)
Range : 563 km
CO2 emissions : 267 g/Km
318tds (1994-1998)
Fuel type : Diesel
Aspiration : Turbo
BMW E36 3 Series Sedan 318 tds Dimensions, Aerodynamics and Weight
Weight-Power Output Ratio : 14.1 kg/cv
BMW E36 3 Series Sedan 318 tds Performance
Top Speed : 182 km/h (113 Mph)
Acceleration 0 to 100 km/h (0 to 62 mph) : 14.4 s
Acceleration 0 to 1000m : 35.5 s
BMW E36 3 Series Sedan 318 tds Consumptions, Emissions and Range
Fuel Consumption - Economy - Efficiency* : 4.4L / 5.8L / 7.6L / -L
Range : km
325td (1991-1998)
Engine Code : M51D25
Fuel type : Diesel
Engine size - Displacement - Engine capacity : 2498 cm3 ( 152.4 cu-in )
Number of valves : 12 Valves
Aspiration : Turbo
Maximum power - Output - Horsepower : 115 PS (113 bhp) (85 kW) @ 4800 rpm
Maximum torque : 222 Nm (163 lb.ft) @ 1900 rpm
BMW E36 3 Series Sedan 325 td Dimensions, Aerodynamics and Weight
Kerb Weight : 1430 kg ( 3153 lbs )
Weight-Power Output Ratio : 12.43 kg/cv
BMW E36 3 Series Sedan 325 td Performance
Acceleration 0 to 100 km/h (0 to 62 mph) : 12.0 s
Acceleration 0 to 1000m : 33.3 s
BMW E36 3 Series Sedan 325 td Consumptions, Emissions and Range
Fuel Consumption - Economy - Efficiency* : 5.1L / 6.8L / 8.9L / 7.4L (31 mpg)
Range : 878 km
CO2 emissions : 172 g/Km
325tds (1993-1998)
Fuel type : Diesel
Aspiration : Turbo
Maximum power - Output - Horsepower : 143 PS (141 bhp) (105 kW) @ 4800 rpm
Maximum torque : 260 Nm (191 lb.ft) @ 2400 rpm
BMW E36 3 Series Sedan 325 tds Dimensions, Aerodynamics and Weight
Weight-Power Output Ratio : 10.07 kg/cv
BMW E36 3 Series Sedan 325 tds Performance
Acceleration 0 to 100 km/h (0 to 62 mph) : 10.4 s
Acceleration 0 to 1000m : 31.4 s
BMW E36 3 Series Sedan 325 tds Consumptions, Emissions and Range
Fuel Consumption - Economy - Efficiency* : 4.9L / 6.5L / 8.8L / -L
Range : km
Mega paldies :super:
