Slēgtās funkcijas
These topics can be coded in your 3 series (E9x). For more information about coding, see here.
Air Conditioning
Save circulation settings
• active
• not active
Circulation settings are saved for next start of the vehicle. (codable in IHKA)
Show ‘Auto’ in automatic mode
• active
• not active
Auto’ is displayed in automatic mode for air conditioning. (codable in IHKA)
Blower level during automatic A/C
• active
• not active
The current blower level is displayed even during automatic mode of the air conditioning. (codable in IHKA)
Blower symbol
• active
• not active
Show blower symbol.(codable in IHKA)
Off-Mode Memory
• active
• not active
Save setting for ‘Off-mode’ for the air conditioning. (codable in IHKA)
Compressor with A/C in ‘Auto’-mode 1/4
• active
• not active
When pressing the ‘Automatic’ button for air conditioning, the air conditioning starts by itself. To deactivate this function, deactivate all functions for ‘Automatic compressor with A/C’.(codable in IHKA)
Compressor with A/C in ‘Auto’-mode 2/4
• active
• not active
Compressor with A/C in ‘Auto’-mode 3/4
• active
• not active
Compressor with A/C in ‘Auto’-mode 4/4
• active
• not active
Residual heat with ‘ALL’-button
• active
• not active
ALL’-button triggers residual heat function of the AC. (codable in IHKA)
Alarm System
Panic alarm with remote
• active
• not active
Press and hold the ‘unlock trunk’ button to trigger the alarm. To activate this function, also activate ‘Panic alarm’ in the DWA module. (codable in CAS)
Arm/Disarm Anti-Theft Alarm System
• Only with remote
• With locks and remote
Anti-theft alarm system is armed/disarmed by locking/unlocking the car (1) with the locks and the remote or (2) only by locking/unlocking the car with the remote. (codable in CAS)
Panic alarm
• active
• not active
Trigger alarm by pressing and holding the ‘unlock tailgate’ button on the remote. To activate this function also activate ‘Panic alarm with remote’ in the CAS module.(codable in DWA)
Audible confirmation – locking vehicle
• active
• not active
Audible confirmation for locking vehicle is active/not active.(codable in DWA)
Audible confirmation – unlocking vehicle
• active
• not active
Audible confirmation for unlocking vehicle is active/not active.(codable in DWA)
Alarm with dimmed headlights
• active
• not active
Dimmed headlights blink when alarm is initiated.(codable in DWA)
Alarm with high beams
• active
• not active
High beams blink when alarm is initiated.(codable in DWA)
Alarm with warning lights
• active
• not active
Warning lights blink when alarm is initiated.(codable in DWA)
Alarm type
• Europe
• USA
• UK
Type and sound of the alarm. United Kingdom is the same sound as Europe, the duration of the alarm is eight times longer. (codable in DWAS)
• active
• not active
Enable menus for audible confirmation for locking/unlocking the vehicle in the iDrive. The menu can be found in the same menu as the other locking confirmation settings in the iDrive. Only works if an ‘Anti Theft Alarm System’ is installed, because the sound is generated by the siren of the anti theft alarm system and not by the horn. If you are not sure, whether an ‘Anti Theft Alarm System’ or only the standard ‘Anti Theft Protection’ is installed, please perform a diagnostic session. You can then check if the module for the anti theft alarm system was found or not. (codable in CCC)
• active
• not active
Display option for audible confirmation for unlocking the vehicle in the iDrive. Please enable ‘Audible confirmation’ for this as well in this module and carefully read the description for it. (codable in CCC)
Audible confirmation – locking vehicle 1/2
• active
• not active
Display option for audible confirmation for locking the vehicle in the iDrive. Please enable ‘Audible confirmation’ for this as well in this module and carefully read the description for it.(codable in CCC)
Audible confirmation – locking vehicle 2/2
• active
• not active
Only change this function with ‘Audible confirmation – locking vehicle 1/2’. (codable in CCC)
Angel Eyes
Daytime running lights – angel eyes
• active
• not active
Use angel eyes as daytime running lights. To activate this function, set ‘Daytime running lights’ to ‘active’ and ‘Daytime running lights – customization’ to ‘Only additional lights’. If you want to increase the brightness, please use ’Daytime running lights – angel eyes brightness’. This coding is only available for cars with an FRM2 or FRM3. These FRM versions started to be installed after ca. 06/2007 in the 3 series (E9x). (codable in FRM)
Angel eyes brightness daytime running lights
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
Brightness of Angel Eyes (Corona rings) for daytime running lights.(codable in FRM)
Angel eyes brightness standing lights
• off
• very low
• low
• medium
• high
• very high
Brightness of Angel Eyes (Corona rings) for standing lights. (codable in FRM)
Angel eyes brightness parking lights
• off
• very low
• low
• medium
• high
• very high
Brightness of Angel Eyes (Corona rings) for parking lights. (codable in FRM)
Brightness of Angel Eyes 1 – alternative
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
Brightness of Angel Eyes. Only use this coding if the standard codings did not work. (codable in FRM)
Brightness of Angel Eyes 2 – alternative
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
Brightness of Angel Eyes when low beams are active. Only use this coding if the standard codings did not work.(codable in FRM)
Brightness of Angel Eyes 3 – alternative
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
Brake lights
Brake force display
• active
• not active
Customized brake lights turn on or flash when braking hard. Use the codings below to customize the brake force display. (codable in FRM)
Brake force display 1/2
• active
• active (alternative)
Customized brake lights turn on or flash when braking hard. Use the codings below to customize the brake force display. To activate this function, set ‘Brake force display 2/2’ to ‘active’. (codable in FRM)
• active
• not active
Only change this function with ‘Brake force display 1/2’. (codable in FRM)
Brake force display – minimum speed
• 20 kph / 12 mph
• 50 kph / 31 mph
Minimum speed threshold for brake force display. In order to enable this option, activate ‘Brake force display’ as well. (codable in FRM)
Brake force display – blinking speed
• slow
• fast
Blinking speed for brake force display. In order to enable this option, activate ‘Brake force display’ as well. (codable in FRM)
Brake force display – angel eyes
• not active
• on
• flashing
Customization for angel eyes for brake force display. In order to enable this option, activate ‘Brake force display’ as well. (codable in FRM)
Brake force display – outer brake lights
• not active
• on
• flashing
Customization for outer brake lights for brake force display. In order to enable this option, activate ‘Brake force display’ as well. (codable in FRM)
Brake force display – inner brake lights
• on
• flashing
Customization for inner brake lights for brake force display. In order to enable this option, activate ‘Brake force display’ as well. (codable in FRM)
Brake force display – third brake light
• not active
• on
• flashing
Customization for third brake lights (rear window) for brake force display. In order to enable this option, activate ‘Brake force display’ as well. (codable in FRM)
Brake force display – tail lights
• not active
• on
• flashing
Customization for tail lights for brake force display. In order to enable this option, activate ‘Brake force display’ as well. (codable in FRM)
Brake force display – rear fog lights
• not active
• on
• flashing
Customization for rear fog lights for brake force display. In order to enable this option, activate ‘Brake force display’ as well. (codable in FRM)
Cleaning
Wiping interval standstill
• 3s
• 5s
Interval in seconds for windscreen wipers at standstill. (codable in JBBF)
Wiping interval rear window
• not active
• 2s
• 4s
• 6s
• 8s
• 12s
Interval in seconds for windscreen rear window wipers. (codable in JBBF)
Rear wiper in reverse gear
• active
• not active
Rear wiper automatically turns on in reverse gear when front wipers are active. (codable in JBBF)
Windscreen wipers continue
• active
• not active
Windscreen wipers don’t stop in the middle of the windscreen when ignition is turned off. Instead they complete their wiping cycle. (codable in JBBF)
Wipe delay after windowscreen cleaning
• 0.1s
• 0.3s
• 0.5s
• 0.7s
Windscreen wipers wipe 0.x seconds after windscreen is cleaned.(codable in JBBF)
Wipe delay after rear window cleaning
• 0.1s
• 0.3s
• 0.5s
• 0.7s
Rear window wipers wipe 0.x seconds after rear window is cleaned.(codable in JBBF)
Number of wipes after windscreen cleaning
• 1
• 2
• 3
• 4
Number of wipes after windscreen is cleaned.(codable in JBBF)
Number of wipes after rear window cleaning
• 1
• 2
• 3
• 4
Number of wipes after rear window is cleaned.(codable in JBBF)
Head light cleaning
• active
• not active
Turn head light cleaning on/off. (codable in JBBF)
Number until headlight cleaning
• 3
• 5
• 7
Head lights are cleaned every x-th time the windscreen washer has been activated. (codable in JBBF)
Number of splashes for head lights
• 2
• 3
Number of splashes for cleaning the head lights.(codable in JBBF)
Length of splash for head lights
• 0.7s
• 1s
• 0.5s
Length of a single splash for head light cleaning.(codable in JBBF)
Delay between splashes for head lights
• 1.3s
• 1s
• 1.5s
Delay between splashes for head light cleaning.(codable in JBBF)
Clock/Date
GPS time correction
• active
• not active
Time of day is corrected by using GPS. (codable in KOMBI)
Comfort Functions
Comfort start
• active
• not active
Ignition key just has to be tapped once to start the engine after ignition is turned on. (codable in CAS)
Comfort eject
• active
• not active
Turn off the ignition with a long press on the start/stop button in order to eject the ignition key.(codable in CAS)
Comfort open using remote
• active
• not active
Press and hold the unlock button on the remote to open all windows and the sunroof. (codable in CAS)
Comfort close using remote
• active
• not active
Press and hold the lock button on the remote to close all windows and the sunroof. (codable in CAS)
Comfort open using keylocks
• active
• not active
Unlock the car by key and hold the key in the unlock position to open all windows and the sunroof. (codable in CAS)
Comfort close using keylocks
• active
• not active
Lock the car by key and hold the key in the lock position to close all windows and the sunroof. (codable in CAS)
Comfort close – door (comfort access)
• active
• not active
Use comfort closing features when locking with the door handle. This only works if comfort access is installed. Touch the locking area on the door handle for a longer time to close all windows and the sunroof. (codable in CAS)
Comfort folding for sideview mirrors
• active
• not active
When holding the lock/unlock button on the remote the sideview mirrors automatically fold/unfold. To activate this function please activate ‘Comfort folding/unfolding for sideview mirrors’ in the ‘FRM’ module. Also activate ‘Comfort open using remote’ and ‘Comfort close using remote’ in this module.(codable in CAS)
Comfort closing delay (mirrors)
• 0.0s
• 0.5s
• 1.5s
General delay for comfort closing. If ‘0.0s’ is set, mirrors fold immediately when car is locked.(codable in CAS)
Deactivate comfort access
• active
• not active
In order to deactivate the comfort access, set this coding to ‘not active’. This coding cannot be used to activate a retrofitted comfort access. When the comfort access is deactivated, neither closing nor opening the car via the door handle will work. Turning the ignition and engine on/off without putting the key into the ignition (also known as ‘Keyless Go’) will also not work anymore. Therefore the car cannot be stolen anymore by tricking the comfort access. In order to activate comfort access again, please set this coding to ‘active’.(codable in CAS)
Coming Home
Activate follow me home lights
• active
• not active
Follow me home lights are active/not active.(codable in FRM)
Follow me home lights with remote
• active
• not active
Quickly press the ‘Open trunk’ button twice to activate the follow me home lights. In some circumstances the function ‘Panic mode remote’ in the CAS has to be activated, too.(codable in FRM)
Cancel follow me home lights
• active
• not active
Follow me home lights are cancelled, when activating the flash to pass again. (codable in FRM)
Extend follow me home lights
• active
• not active
Follow me home lights are displayed longer, when activating the flash to pass again. (codable in FRM)
Follow me home lights duration
• off
• 40s
• 90s
• 150s
• 240s
Duration of follow me home lights in seconds. To activate follow me home lights, activate the flash to pass, while the enginge is off. (codable in FRM)
Follow me home lights duration Key 1
• off
• 40s
• 90s
• 150s
• 240s
Separate setting for duration in seconds of follow me home lights for key 1. (codable in FRM)
Follow me home lights duration Key 2
• off
• 40s
• 90s
• 150s
• 240s
Separate setting for duration in seconds of follow me home lights for key 2. (codable in FRM)
Follow me home lights duration Key 3
• off
• 40s
• 90s
• 150s
• 240s
Separate setting for duration in seconds of follow me home lights for key 3. (codable in FRM)
Convertible
Speed limit roof open/close
• 6 kph / 4 mph
• 30 kph / 19 mph
• 50 kph / 31 mph
Speed limit for closing/opening the roof while driving. For pre-facelift models 30 kph is recommended, due to the less stable construction of the roof. (codable in CTM)
Corner LEDs
Corner LEDs
• active
• not active
Corner LEDs are active/not active – also known as ‘Corner Delete Mod’. This function often only works on US models to deactivate the corner LEDs. (codable in FRM)
Corner LEDs brightness – low beams
• off
• low
• medium
• high
Brightness of corner LEDs when low beams are active. (codable in FRM)
Corner LEDs brightness – high beams
• off
• low
• medium
• high
Brightness of corner LEDs when high beams are active. (codable in FRM)
Cornering Light
Cornering lights 1/3
• active
• not active
Use front fog lights/high beams as cornering lights. Also, this function often requires adaptive headlights to be installed. (codable in FRM)
Cornering lights 2/3
• active
• not active
Only change this function with ‘Cornering lights 1/3’. Also, this function often requires adaptive headlights to be installed. (codable in FRM)
Cornering lights 3/3
• active
• not active
Cornering lights – front fog lights
• active
• not active
Front fog lights are used as cornering lights. Only works if ‘Cornering lights’ is also activated.(codable in FRM)
Cornering lights – reverse gear
• active
• not active
Use cornering lights also when reversing. Only works if ‘Cornering lights’ is also activated.(codable in FRM)
Cornering lights – brightness
• off
• very low
• low
• medium
• high
• very high
Brightness of ‘Cornering lights’. Only works if ‘Cornering lights’ is also activated. (codable in FRM)
Cornering lights – key 1
• active
• not active
Cornering lights are active/not active. Separate setting for ‘Cornering lights’ for key 1. Only works if ‘Cornering lights’ is also activated. (codable in FRM)
Cornering lights – key 2
• active
• not active
Cornering lights are active/not active. Separate setting for ‘Cornering lights’ for key 2. Only works if ‘Cornering lights’ is also activated. (codable in FRM)
Cornering lights – key 3
• active
• not active
Cornering lights are active/not active. Separate setting for ‘Cornering lights’ for key 3. Only works if ‘Cornering lights’ is also activated. (codable in FRM)
Cornering lights – key 4
• active
• not active
Cornering lights are active/not active. Separate setting for ‘Cornering lights’ for key 4. Only works if ‘Cornering lights’ is also activated. (codable in FRM)
Cornering Light
• active
• not active
Display menu for activating cornering light in the iDrive. The menu can be found in the same menu as the other light settings in the iDrive. Also, cornering light often requires adaptive headlights to be installed. (codable in CCC)
Daytime Running Lights
Daytime running lights in OBC
• active
• not active
Turn daytime running lights on/off in on board computer. Might not work if an iDrive system is installed. (codable in KOMBI)
Daytime running lights 1/2
• active
• not active
Daytime running lights (DRL) is active/not active. The DRL is activated when the light switch is set to position ‘0’ in the car. Please activate ‘Daytime running lights 2/2’ as well.(codable in FRM)
• active
• not active
Daytime running lights (DRL) is active/not active. The DRL is activated when the light switch is set to position ‘0’ in the car. Please activate ‘Daytime running lights 1/2’ as well.(codable in FRM)
Daytime running lights – Key 1
• active
• not active
Daytime running lights are active/not active. Separate setting for ‘Daytime running lights’ for key 1. (codable in FRM)
Daytime running lights – Key 2
• active
• not active
Daytime running lights are active/not active. Separate setting for ‘Daytime running lights’ for key 2. (codable in FRM)
Daytime running lights – Key 3
• active
• not active
Daytime running lights are active/not active. Separate setting for ‘Daytime running lights’ for key 3. (codable in FRM)
Daytime running lights customization
• not active
• dimmed turn signals
• dimmed high beams
Customization of the daytime running lights. Brightness can be set with ‘Daytime running lights brightness’.(codable in FRM)
• very low
• low
• medium
• high
• very high
Brightness for dimmed daytime running lights. To use this function, also activate ‘Daytime running lights customization’.(codable in FRM)
• Off
• Low beams
• High beams
• Only additional lights (EU models)
• Only additional lights (US models)
Customization of the daytime running lights (DRL). The DRL is activated when the light switch is set to position ‘0’ in the car. This coding is only available for cars with an FRM2 or FRM3. These FRM versions started to be installed after ca. 06/2007 in the 3 series (E9x). (codable in FRM)
Daytime running lights – high beams brightness
• off
• very low
• low
• medium
• high
• very high
Brightness of high beams for daytime running lights. To activate the high beams for daytime running lights, set ‘Daytime running lights – customization’ to ‘High beams’. This coding is only available for cars with an FRM2 or FRM3. These FRM versions started to be installed after ca. 06/2007 in the 3 series (E9x). (codable in FRM)
Daytime running lights – front fog lights
• active
• not active
Use front fog lights as daytime running lights. To activate this function, set ‘Daytime running lights’ to ‘active’. This coding is only available for cars with an FRM2 or FRM3. These FRM versions started to be installed after ca. 06/2007 in the 3 series (E9x). (codable in FRM)
Daytime running lights – front fog lights brightness
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
Brightness for ‘Daytime running lights – front fog lights’. This coding is only available for cars with an FRM2 or FRM3. These FRM versions started to be installed after ca. 06/2007 in the 3 series (E9x). (codable in FRM)
Daytime running lights – front turn signals
• active
• not active
Use front turn signals as daytime running lights. To activate this function, set ‘Daytime running lights’ to ‘active’. This coding is only available for cars with an FRM2 or FRM3. These FRM versions started to be installed after ca. 06/2007 in the 3 series (E9x). (codable in FRM)
• active
• not active
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
Daytime running lights – sidemarker
• active
• not active
Use sidemarkers as daytime running lights. To activate this function, set ‘Daytime running lights’ to ‘active’. This coding is only available for cars with an FRM2 or FRM3. These FRM versions started to be installed after ca. 06/2007 in the 3 series (E9x). (codable in FRM)
Daytime running lights – number plate lighting
• active
• not active
Use number plate lighting as daytime running lights. To activate this function, set ‘Daytime running lights’ to ‘active’. This coding is only available for cars with an FRM2 or FRM3. These FRM versions started to be installed after ca. 06/2007 in the 3 series (E9x). (codable in FRM)
Daytime running lights – tail lights
• active
• not active
Use tail lights as daytime running lights. To activate this function, set ‘Daytime running lights’ to ‘active’. This coding is only available for cars with an FRM2 or FRM3. These FRM versions started to be installed after ca. 06/2007 in the 3 series (E9x). (codable in FRM)
Daytime running lights – inner brake lights
• active
• not active
Use inner brake lights as daytime running lights. To activate this function, set ‘Daytime running lights’ to ‘active’. This coding is only available for cars with an FRM2 or FRM3. These FRM versions started to be installed after ca. 06/2007 in the 3 series (E9x). (codable in FRM)
Daytime running lights – 3rd brake lights
• active
• not active
Use 3rd brake lights as daytime running lights. To activate this function, set ‘Daytime running lights’ to ‘active’. This coding is only available for cars with an FRM2 or FRM3. These FRM versions started to be installed after ca. 06/2007 in the 3 series (E9x). (codable in FRM)
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
Daytime running lights – tail lights brightness
• off
• very low
• low
• medium
• high
• very high
Brightness for ‘Daytime running lights – tail lights’. (codable in FRM)
• standard
• permanently on
• permanently off
Set mode of daytime running lights. (codable in CIC)
Easy Entry
Easy entry
• active
• not active
If the car is unlocked by pressing the unlock button twice, the driver window will lower as soon as the door is opened. (codable in CAS)
Easy entry Key 1
• active
• not active
Separate setting for ‘Easy entry’ for key 1nPress the unlock button once to unlock all doors. Press it again to lower the driver side window. (codable in CAS)
Easy entry Key 2
• active
• not active
Separate setting for ‘Easy entry’ for key 2nPress the unlock button once to unlock all doors. Press it again to lower the driver side window. (codable in CAS)
Easy entry Key 3
• active
• not active
Separate setting for ‘Easy entry’ for key 3nPress the unlock button once to unlock all doors. Press it again to lower the driver side window. (codable in CAS)
Engine Start Stop
Start/Stop-Automatic memory
• active
• not active
Setting for Start/Stop-Automatic is saved for the next start. Deactivating the Start/Stop-Automatic on the car can increase the life time of the battery and the starter. (codable in IHKA)
Flash to Pass
Flash to pass with bi-xenon
• active
• not active
Bi-xenon lamps are used for flash to pass.(codable in FRM)
Front fog lights with flash to pass
• active
• not active
Front fog lights are automatically turned off when activating flash to pass. (codable in FRM)
Gear Shift Indicator
Gear shift indicator 1/2
• active
• not active
Gear shift indicator in the on board computer. To activate this function, also activate other codings for ‘Gear shift indicator’. (codable in KOMBI)
Gear shift indicator 2/2
• active
• not active
Only change with ‘Gear shift indicator 1/2’.(codable in KOMBI)
Gear shift indicator key 1
• active
• not active
Gear shift indicator for key 1. (codable in KOMBI)
Gear shift indicator key 2
• active
• not active
Gear shift indicator for key 2. (codable in KOMBI)
Gear shift indicator key 3
• active
• not active
Gear shift indicator for key 3. (codable in KOMBI)
Gear shift indicator key 4
• active
• not active
Gear shift indicator for key 4. (codable in KOMBI)
Headlight Cleaning
Head light cleaning
• active
• not active
• 3
• 5
• 7
• 2
• 3
• 0.7s
• 1s
• 0.5s
• 1.3s
• 1s
• 1.5s
High Beam
Front fog lights with high beams
• active
• not active
Front fog lights are automatically turned off when activating high beams. (codable in FRM)
iDrive Menus
Audible confirmation menu
• active
• not active
Show menu for audible confirmation for locking/unlocking in iDrive. This coding only works when the DWA module is installed.(codable in CIC)
Address book menu
• active
• not active
Show menu for address book in iDrive. (codable in CIC)
Notepad menu
• active
• not active
Show menu for notepad in iDrive. (codable in CIC)
• active
• not active
• active
• not active
• active
• not active
• active
• not active
Rain light sensor sensitivity 1/2
• active
• not active
Display menu for changing the sensitivity of the rain light sensor in the iDrive. The menu can be found in the same menu as the other light settings in the iDrive.(codable in CCC)
Rain light sensor sensitivity 2/2
• active
• not active
Only change this function with ‘Rain light sensor sensitivity 1/2’. (codable in CCC)
Seat heater
• active
• not active
Display menu for changing the heat distribution of the seat heater. The menu can be found in the same menu as the other heater settings in the iDrive. Also, changing the heating distribution often only works on 5 series with sport seats.(codable in CCC)
Cornering Light
• active
• not active
Instrument Cluster
Digital speedometer
• active
• not active
The current speed is shown in the digital display below the speedometer. (codable in KOMBI)
Digital speedometer correction
• true speed
• ‘corrected’ speed
Per default the speed shown in the digital speedometer is ‘corrected’ by the car. This has the effect that the shown speed is a bit higher than the true speed of the car.(codable in KOMBI)
Correction’ analog speedometer
• true speed
• ‘corrected’ speed
This coding does not work on US models. Per default the speed shown in the digital speedometer is ‘corrected’ by the car. This has the effect that the shown speed is a bit higher than the true speed of the car.(codable in KOMBI)
Blank information display in dashboard
• active
• not active
Blank information display in dashboard is shown when you switch the information displays with the BC button. (codable in KOMBI)
GPS time correction
• active
• not active
Permanent speedometer lighting
• active
• not active
Speedometer is always lit, even in the daytime.(codable in KOMBI)
Momentary fuel consumption
• active
• not active
Show momentary fuel consumption in the on board computer.(codable in KOMBI)
Cruise Control speed display
• 0s
• 3s
• 6s
The set speed of the cruise control is shown for a couple of seconds in the on board computer.(codable in KOMBI)
• active
• not active
Light sensitivity in OBC 1/2
• active
• not active
Change light sensitivity in on board computer. Might not work if an iDrive system is installed.(codable in KOMBI)
Light sensitivity in OBC 2/2
• active
• not active
Only change with ‘Light sensitivity in OBC 1/2’.(codable in KOMBI)
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
Interior Lights
Interior lights with remote
• active
• not active
Pressing the lock button on the remote, when the car is already locked, turns on the interior lights. (codable in CAS)
Interior lighting off after 2 minutes
• active
• not active
Interior lighting is automatically turned off after two minutes.(codable in FRM)
Soft turn on/off for interior lighting
• active
• not active
Interior lighting is softly turned on and off.(codable in FRM)
Legal Disclaimer
Legal disclaimer (US)
• active
• not active
Show legal disclaimer when iDrive is started. This warning is usually only shown in US-models. (codable in CIC)
Camera disclaimer
• active
• active (6 seconds)
• not active
Show legal disclaimer for rear view camera.(codable in CIC)
Night Vision disclaimer
• active
• not active
Show legal disclaimer for night vision view camera.(codable in CIC)
• active
• not active
Show legal disclaimer when iDrive is started. This warning is usually only shown in US-models. (codable in CCC)
Legal disclaimer (US) – display time
• 0s
• 10s
Display time for the legal disclaimer in the iDrive. Setting this function to ‘0s’ deactivates the legal disclaimer and sometimes even speeds up the starting time of the iDrive. This warning is usually only shown in US-models. (codable in CCC)
Locking
• active
• not active
• active
• not active
• active
• not active
• 0.0s
• 0.5s
• 1.5s
• active
• not active
Lock tailgate when car locked
• active
• not active
Tailgate cannot be unlocked, when car is locked. (codable in CAS)
Automatically lock vehicle duration
• 1 min
• 2 min
• 5 min
• 10 min
• 15 min
Duration in minutes until doors are locked after car was unlocked but no windows or doors have been opened. (codable in CAS)
Automatically lock vehicle Key 1
• active
• not active
Separate setting for ‘Automatically lock vehicle’ for key 1nIf no door or window has been opened two minutes after the car has been unlocked, the doors automatically lock.(codable in CAS)
Automatically lock vehicle Key 2
• active
• not active
Separate setting for ‘Automatically lock vehicle’ for key 2nIf no door or window has been opened two minutes after the car has been unlocked, the doors automatically lock.(codable in CAS)
Automatically lock vehicle Key 3
• active
• not active
Separate setting for ‘Automatically lock vehicle’ for key 3nIf no door or window has been opened two minutes after the car has been unlocked, the doors automatically lock.(codable in CAS)
Automatically lock vehicle Key 4
• active
• not active
Separate setting for ‘Automatically lock vehicle’ for key 4nIf no door or window has been opened two minutes after the car has been unlocked, the doors automatically lock.(codable in CAS)
Lock vehicle upon ignition
• active
• not active
Vehicle is locked, when ignition is turned on.(codable in CAS)
Threshold speed for vehicle locking
• 2 kph / 1 mph
• 6 kph / 4 mph
• 12 kph / 8 mph
• 18 kph / 11 mph
• 24 kph / 15 mph
• 30 kph / 19 mph
Sets the speed at which the vehicle automatically locks all doors.nTo activate this function you need to activate ‘Lock vehicle at x kph’ for the according keys. (codable in CAS)
Lock vehicle at x kph Key 1
• active
• not active
Automatically lock the vehicle at the set threshold speed when key 1 is used. (codable in CAS)
Lock vehicle at x kph Key 2
• active
• not active
Automatically lock the vehicle at the set threshold speed when key 2 is used. (codable in CAS)
Lock vehicle at x kph Key 3
• active
• not active
Automatically lock the vehicle at the set threshold speed when key 3 is used. (codable in CAS)
Lock vehicle at x kph Key 4
• active
• not active
Automatically lock the vehicle at the set threshold speed when key 4 is used. (codable in CAS)
Optical confirmation – locking vehicle
• active
• not active
Optical confirmation for locking vehicle is active/not active.(codable in FRM)
Optical confirmation lock vehicle Key 1
• active
• not active
Optical confirmation for locking vehicle is active/not active. Separate setting for ‘Optical confirmation for locking’ for key 1.(codable in FRM)
Optical confirmation lock vehicle Key 2
• active
• not active
Optical confirmation for locking vehicle is active/not active. Separate setting for ‘Optical confirmation for locking’ for key 2.(codable in FRM)
Optical confirmation lock vehicle Key 3
• active
• not active
Optical confirmation for locking vehicle is active/not active. Separate setting for ‘Optical confirmation for locking’ for key 3.(codable in FRM)
• active
• not active
Mirrors
Mirror tilt 1/2
• active
• not active
Requirement for mirror tilt functions. (codable in FRM)
Mirror tilt 2/2
• active
• not active
Tilt mirror in reverse
• active
• not active
This function requires an installed LIN-Bus (usually installed with mirror heating).nPassenger mirror is tilted when switching into reverse gear and the mirror switch is set to the driver side. To activate this function activate ‘Mirror tilt’ as well. (codable in FRM)
• active
• not active
This function requires an installed LIN-Bus (usually installed with mirror heating).nWhen holding the lock/unlock button on the remote the sideview mirrors automatically fold/unfold. May need additional coding of the ‘CAS’ module. (codable in FRM)
Electrochromatic mirror dimming
• active
• not active
This function requires an installed LIN-Bus (usually installed with mirror heating)nSide mirrors automatically dim electrochromatic.(codable in FRM)
Opening
• active
• not active
• active
• not active
• active
• not active
Easy entry
• active
• not active
Easy entry Key 1
• active
• not active
Easy entry Key 2
• active
• not active
Easy entry Key 3
• active
• not active
Easy entry Key 4
• active
• not active
Separate setting for ‘Easy entry’ for key 4nPress the unlock button once to unlock all doors. Press it again to lower the driver side window. (codable in CAS)
Selective central locking
• active
• not active
Unlocking the car once only unlocks the driver’s door. Unlocking it again unlocks the other doors, too. (codable in CAS)
Selective central locking Key 1
• active
• not active
Separate setting for ‘Selective central locking’ for key 1nUnlocking the car once only unlocks the driver’s door. Unlocking it again unlocks the other doors, too. (codable in CAS)
Selective central locking Key 2
• active
• not active
Separate setting for ‘Selective central locking’ for key 2nUnlocking the car once only unlocks the driver’s door. Unlocking it again unlocks the other doors, too. (codable in CAS)
Selective central locking Key 3
• active
• not active
Separate setting for ‘Selective central locking’ for key 3nUnlocking the car once only unlocks the driver’s door. Unlocking it again unlocks the other doors, too. (codable in CAS)
Selective central locking Key 4
• active
• not active
Separate setting for ‘Selective central locking’ for key 4nUnlocking the car once only unlocks the driver’s door. Unlocking it again unlocks the other doors, too. (codable in CAS)
Selective central locking – unlock fuel lid
• active
• not active
The fuel lid is also unlocked upon the first unlock, when ‘Selective central locking’ is active.(codable in CAS)
Unlock car when turned off
• active
• not active
Doors are automatically unlocked, when ignition key is ejected. Only works if ‘Lock vehicle at x kph Key 1-4’ is activated.(codable in CAS)
Optical confirmation – unlocking vehicle
• active
• not active
Optical confirmation for unlocking vehicle is active/not active.(codable in FRM)
Optical confirmation unlock vehicle Key 1
• active
• not active
Optical confirmation for unlocking vehicle is active/not active. Separate setting for ‘Optical confirmation for unlocking’ for key 1.(codable in FRM)
Optical confirmation unlock vehicle Key 2
• active
• not active
Optical confirmation for unlocking vehicle is active/not active. Separate setting for ‘Optical confirmation for unlocking’ for key 2.(codable in FRM)
Optical confirmation unlock vehicle Key 3
• active
• not active
Optical confirmation for unlocking vehicle is active/not active. Separate setting for ‘Optical confirmation for unlocking’ for key 3.(codable in FRM)
• active
• not active
Park Distance Control (PDC)
PDC view
• vertical (F-Models)
• horizontal (E-Models)
Direction of park distance control view.(codable in CIC)
Parking Light
Comfort standing light
• active
• not active
If the light switch is set at automatic or on, the parking lights remain on, until the vehicle is locked with the remote. (codable in FRM)
Power Windows
Power windows after ignition off
• active
• not active
Power windows are active for another minute after ignition is turned off. (codable in CAS)
• 1 min
• 2 min
• 5 min
• 10 min
• 15 min
Duration in minutes, for which power windows are active after turning off the ignition. (codable in CAS)
Easy entry
• active
• not active
Easy entry Key 1
• active
• not active
Easy entry Key 2
• active
• not active
Easy entry Key 3
• active
• not active
Easy entry Key 4
• active
• not active
Continue window action when door is opened
• active
• not active
When the door is opened while its window is opening/closing, the window will continue opening/closing the window. (codable in FRM)
Continue window action when engine started
• active
• not active
When the engine is started while a window is opening/closing, the window will continue opening/closing the window. (codable in FRM)
Rain Light Sensor
• active
• not active
• active
• not active
Seatbelt Hand-over
Seatbelt Hand-Over
• active
• not active
Automatic seatbelt hand-over is active/inactive.(codable in FRM)
Seatbelt Hand-Over driver
• active
• not active
Automatic seatbelt hand-over for driver is active/inactive. (codable in FRM)
Seatbelt Hand-Over passenger
• active
• not active
Automatic seatbelt hand-over for passenger is active/inactive. (codable in FRM)
Seating Heater
Seat heater
• active
• not active
Seat heater level in menu
• active
• not active
Show the current seat heater level for the front seats in the seat heater menu. (codable in CCC)
Show seat heater menu automatically
• active
• not active
Show seat heater menu for a few seconds when activating the seat heater. This function often only works in 5 series models. (codable in CCC)
Sidemarker
Sidemarker (US)
• active
• not active
Sidemarkers are permanently active. May need additional ‘Sidemarker (US)’ functions set to ‘active’ if available. If warnings for the turn signals are shown after successfully coding this, please disable the voltage monitoring for the turn signals. This warning is most likely due to the fact that your car is not a US model. (codable in FRM)
Sidemarker (US) brightness
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
Brightness for ‘Sidemarker (US)’.(codable in FRM)
Speedometer
Digital speedometer
• active
• not active
• true speed
• ‘corrected’ speed
• true speed
• ‘corrected’ speed
Tail gate/Rear lid
Unlock rear window
• active
• not active
Key unlocks rear window instead of trunk lid in touring models. (codable in CAS)
Unlock rear window key 1
• active
• not active
Key 1 unlocks rear window instead of trunk lid in touring models.(codable in CAS)
Unlock rear window key 2
• active
• not active
Key 2 unlocks rear window instead of trunk lid in touring models.(codable in CAS)
Unlock rear window key 3
• active
• not active
Key 3 unlocks rear window instead of trunk lid in touring models.(codable in CAS)
Unlock rear window key 4
• active
• not active
Key 4 unlocks rear window instead of trunk lid in touring models.(codable in CAS)
Unlock rear window via outside button
• active
• not active
Outside trunk lid button opens rear window instead of trunk lid in touring models. (codable in CAS)
Unlock rear window via outside button Key 1
• active
• not active
Outside trunk lid button opens rear window instead of trunk lid in touring models. Separate setting for key 1.(codable in CAS)
Unlock rear window via outside button Key 2
• active
• not active
Outside trunk lid button opens rear window instead of trunk lid in touring models. Separate setting for key 2.(codable in CAS)
Unlock rear window via outside button Key 3
• active
• not active
Outside trunk lid button opens rear window instead of trunk lid in touring models. Separate setting for key 3.(codable in CAS)
Unlock rear window via outside button Key 4
• active
• not active
Outside trunk lid button opens rear window instead of trunk lid in touring models. Separate setting for key 4.(codable in CAS)
Unlock rear window with footwell switch
• active
• not active
Footwell switch opens rear window instead of trunk lid in touring models. (codable in CAS)
Open rear window via footwell switch Key 1
• active
• not active
Footwell switch opens rear window instead of trunk lid in touring models. Separate setting for key 1. (codable in CAS)
Open rear window via footwell switch Key 2
• active
• not active
Footwell switch opens rear window instead of trunk lid in touring models. Separate setting for key 2. (codable in CAS)
Open rear window via footwell switch Key 3
• active
• not active
Footwell switch opens rear window instead of trunk lid in touring models. Separate setting for key 3. (codable in CAS)
Open rear window via footwell switch Key 4
• active
• not active
Footwell switch opens rear window instead of trunk lid in touring models. Separate setting for key 4. (codable in CAS)
Tank
Threshold for low range warning
• off
• 20 km / 12 mi
• 50 km / 31 mi
Threshold for acoustic low range warning due to low fuel level. (codable in KOMBI)
Threshold for tank reserve warning
• 6.5 litres
• 8.0 litres
• 10.0 litres
• 12.5 litres
• 20.0 litres
Threshold for tank reserve warning due to low fuel level. (codable in KOMBI)
Telephone
Telephone ringtone
• BMW
• Mini
Customize telephone ringtone. (codable in CIC)
Turn signals
Hazard lights
• standard
• double
Hazard lights blink once or twice. (codable in FRM)
Crash lights
• standard
• double
Hazard lights blink once or twice upon an accident. (codable in FRM)
One-touch turn signal function
• 1
• 3
• 5
Number of turn signals when tapping the turn signal. If available, please activate this option for the different keys as well. In some cases, this option also needs to be enabled in the iDrive.(codable in FRM)
One-touch turn signal function Key 1
• 1
• 3
• 5
Number of turn signals when tapping the turn signal. Separate setting for ‘One-touch turn signal function’ for key 1.(codable in FRM)
One-touch turn signal function Key 2
• 1
• 3
• 5
Number of turn signals when tapping the turn signal. Separate setting for ‘One-touch turn signal function’ for key 2.(codable in FRM)
One-touch turn signal function Key 3
• 1
• 3
• 5
Number of turn signals when tapping the turn signal. Separate setting for ‘One-touch turn signal function’ for key 3.(codable in FRM)
Turn signals front as LED
• active
• not active
Activate this option if you have replaced the turn signals front with LED bulbs. (codable in FRM)
Turn signals rear as LED
• active
• not active
Activate this option if you have replaced the turn signals rear with LED bulbs. (codable in FRM)
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
Video in Motion
Video in motion 1/2
• active
• not active
Enable video and DVD while driving. This is only possible if the car supports watching TV or playing DVDs while standing. In order to enable this option, activate ‘Video in motion 2/2’ as well. (codable in CIC)
Video in motion 2/2
• active
• not active
Only change this function with ‘Video in motion 1/2’. This is only possible if the car supports watching TV or playing DVDs while standing.(codable in CIC)
Video in motion
• during driving
• only walking pace
• only when handbrake pulled
• not active
Enable video and DVD while driving. This is only possible if the car supports watching TV or playing DVDs while standing. (codable in CCC)
Voltage Monitoring
Angel Eyes voltage monit. 1/2
• active
• not active
Voltage monitoring for angel eyes. Might cause flickering of LED lights.(codable in FRM)
Angel Eyes voltage monit. 2/2
• active
• not active
Deactivate with ‘Angel Eyes voltage monit. 1/2’ to disable flickering of LED lights. (codable in FRM)
Turn signals front voltage monit. 2/2
• active
• not active
Deactivate with ‘Turn signals front voltage monit. 1/2’ to disable flickering of LED lights.(codable in FRM)
Fog lights voltage monit. 1/2
• active
• not active
Voltage monitoring for fog lights. Might cause flickering of LED lights.(codable in FRM)
Fog lights voltage monit. 2/2
• active
• not active
Deactivate with ‘Fog lights voltage monit. 1/2’ to disable flickering of LED lights. (codable in FRM)
High beams voltage monit. 1/2
• active
• not active
Voltage monitoring for high beams. Might cause flickering of LED lights.(codable in FRM)
High beams voltage monit. 2/2
• active
• not active
Deactivate with ‘High beams voltage monit. 1/2’ to disable flickering of LED lights. (codable in FRM)
Low beams voltage monit. 1/2
• active
• not active
Voltage monitoring for low beams. Might cause flickering of LED lights.(codable in FRM)
Low beams voltage monit. 2/2
• active
• not active
Deactivate with ‘Low beams voltage monit. 1/2’ to disable flickering of LED lights. (codable in FRM)
Turn signals rear voltage monit. 1/2
• active
• not active
Voltage monitoring for turn signals rear. Might cause flickering of LED lights. (codable in FRM)
Turn signals rear voltage monit. 2/2
• active
• not active
Deactivate with ‘Turn signals rear voltage monit. 1/2’ to disable flickering of LED lights.(codable in FRM)
Braking lights voltage monit. 1/2
• active
• not active
Voltage monitoring for braking lights. Might cause flickering of LED lights. (codable in FRM)
Braking lights voltage monit. 2/2
• active
• not active
Deactivate with ‘Braking lights voltage monit. 1/2’ to disable flickering of LED lights. (codable in FRM)
Inner brake light voltage monit. 1/2
• active
• not active
Voltage monitoring for inner brake light. Might cause flickering of LED lights. (codable in FRM)
Inner brake light voltage monit. 2/2
• active
• not active
Deactivate with ‘Inner brake light voltage monit. 1/2’ to disable flickering of LED lights. (codable in FRM)
Third brake light voltage monit. 1/2
• active
• not active
Voltage monitoring for third brake light. Might cause flickering of LED lights. (codable in FRM)
Third brake light voltage monit. 2/2
• active
• not active
Deactivate with ‘Third brake light voltage monit. 1/2’ to disable flickering of LED lights. (codable in FRM)
Tail lights voltage monit. 1/2
• active
• not active
Voltage monitoring for tail lights. Might cause flickering of LED lights.(codable in FRM)
License plate lighting voltage monit. 1/2
• active
• not active
Voltage monitoring for license plate lighting. Might cause flickering of LED lights. (codable in FRM)
License plate lighting voltage monit. 2/2
• active
• not active
Deactivate with ‘License plate lighting voltage monit. 1/2’ to disable flickering of LED lights.(codable in FRM)
Rear fog lights voltage monit. 1/2
• active
• not active
Voltage monitoring for rear fog lights. Might cause flickering of LED lights. (codable in FRM)
Rear fog lights voltage monit. 2/2
• active
• not active
Deactivate with ‘Rear fog lights voltage monit. 1/2’ to disable flickering of LED lights. (codable in FRM)
Rear fog light left voltage monit. 1/2
• active
• not active
Voltage monitoring for rear left fog light. Might cause flickering of LED lights. (codable in FRM)
Rear fog light left voltage monit. 2/2
• active
• not active
Deactivate with ‘Rear fog light left voltage monit. 1/2’ to disable flickering of LED lights. (codable in FRM)
Rear fog light right voltage monit. 1/2
• active
• not active
Voltage monitoring for rear right fog light. Might cause flickering of LED lights. (codable in FRM)
Rear fog light right voltage monit. 2/2
• active
• not active
Deactivate with ‘Rear fog light right voltage monit. 1/2’ to disable flickering of LED lights. (codable in FRM)
Warnings
Speed limit warning
• not active
• 120 kph / 75 mph
• 190 kph / 120 mph
• 210 kph / 130 mph
• 240 kph / 150 mph
Speed limit warning at 120 kph is active/not active. (codable in KOMBI)
Temperature warning
• active
• not active
Warning for outside temperature below 4° C / 39° F is active/not active.(codable in KOMBI)
Ignition key warning
• active
• not active
Ignition key warning active/not active.(codable in KOMBI)
• off
• 20 km / 12 mi
• 50 km / 31 mi
• 6.5 litres
• 8.0 litres
• 10.0 litres
• 12.5 litres
• 20.0 lit
            Air Conditioning
• active
• not active
• active
• not active
• active
• not active
Blower symbol
• active
• not active
Off-Mode Memory
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
Alarm System
• active
• not active
• Only with remote
Panic alarm
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
Alarm type
• Europe
• USA
• UK
• active
• not active
• active
• not active
• active
• not active
• active
• not active
Angel Eyes
• active
• not active
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
• off
• very low
• low
• medium
• high
• very high
• off
• very low
• low
• medium
• high
• very high
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
Brake lights
Brake force display
• active
• not active
• active
• active
• not active
• 20 kph / 12 mph
• 50 kph / 31 mph
• slow
• fast
• not active
• on
• flashing
• not active
• on
• flashing
• on
• flashing
• not active
• on
• flashing
• not active
• on
• flashing
• not active
• on
• flashing
Cleaning
• 3s
• 5s
• not active
• 2s
• 4s
• 6s
• 8s
• 12s
• active
• not active
• active
• not active
• 0.1s
• 0.3s
• 0.5s
• 0.7s
• 0.1s
• 0.3s
• 0.5s
• 0.7s
• 1
• 2
• 3
• 4
• 1
• 2
• 3
• 4
Head light cleaning
• active
• not active
• 3
• 5
• 7
• 2
• 3
• 0.7s
• 1s
• 0.5s
• 1.3s
• 1s
• 1.5s
Clock/Date
GPS time correction
• active
• not active
Comfort Functions
Comfort start
• active
• not active
Comfort eject
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• 0.0s
• 0.5s
• 1.5s
• active
• not active
Coming Home
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• off
• 40s
• 90s
• 150s
• 240s
• off
• 40s
• 90s
• 150s
• 240s
• off
• 40s
• 90s
• 150s
• 240s
• off
• 40s
• 90s
• 150s
• 240s
Convertible
• 6 kph / 4 mph
• 30 kph / 19 mph
• 50 kph / 31 mph
Corner LEDs
Corner LEDs
• active
• not active
• off
• low
• medium
• high
• off
• low
• medium
• high
Cornering Light
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• off
• very low
• low
• medium
• high
• very high
• active
• not active
• active
• not active
• active
• not active
• active
• not active
Cornering Light
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• not active
• dimmed high beams
• very low
• low
• medium
• high
• very high
• Off
• Low beams
• High beams
• off
• very low
• low
• medium
• high
• very high
• active
• not active
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
• active
• not active
• active
• not active
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
• off
• very low
• low
• medium
• high
• very high
• standard
• permanently on
• permanently off
Easy Entry
Easy entry
• active
• not active
Easy entry Key 1
• active
• not active
Easy entry Key 2
• active
• not active
Easy entry Key 3
• active
• not active
Engine Start Stop
• active
• not active
Flash to Pass
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
Headlight Cleaning
Head light cleaning
• active
• not active
• 3
• 5
• 7
• 2
• 3
• 0.7s
• 1s
• 0.5s
• 1.3s
• 1s
• 1.5s
High Beam
• active
• not active
iDrive Menus
• active
• not active
Address book menu
• active
• not active
Notepad menu
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
Seat heater
• active
• not active
Cornering Light
• active
• not active
Instrument Cluster
Digital speedometer
• active
• not active
• true speed
• ‘corrected’ speed
• true speed
• ‘corrected’ speed
• active
• not active
GPS time correction
• active
• not active
• active
• not active
• active
• not active
• 0s
• 3s
• 6s
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
Interior Lights
• active
• not active
• active
• not active
• active
• not active
Legal Disclaimer
• active
• not active
Camera disclaimer
• active
• not active
• active
• not active
• active
• not active
• 0s
• 10s
Locking
• active
• not active
• active
• not active
• active
• not active
• 0.0s
• 0.5s
• 1.5s
• active
• not active
• active
• not active
• 1 min
• 2 min
• 5 min
• 10 min
• 15 min
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• 2 kph / 1 mph
• 6 kph / 4 mph
• 12 kph / 8 mph
• 18 kph / 11 mph
• 24 kph / 15 mph
• 30 kph / 19 mph
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
Mirrors
Mirror tilt 1/2
• active
• not active
Mirror tilt 2/2
• active
• not active
• active
• not active
• active
• not active
• active
• not active
Opening
• active
• not active
• active
• not active
• active
• not active
Easy entry
• active
• not active
Easy entry Key 1
• active
• not active
Easy entry Key 2
• active
• not active
Easy entry Key 3
• active
• not active
Easy entry Key 4
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
PDC view
Parking Light
• active
• not active
Power Windows
• active
• not active
• 1 min
• 2 min
• 5 min
• 10 min
• 15 min
Easy entry
• active
• not active
Easy entry Key 1
• active
• not active
Easy entry Key 2
• active
• not active
Easy entry Key 3
• active
• not active
Easy entry Key 4
• active
• not active
• active
• not active
• active
• not active
Rain Light Sensor
• active
• not active
• active
• not active
Seatbelt Hand-over
Seatbelt Hand-Over
• active
• not active
• active
• not active
• active
• not active
Seating Heater
Seat heater
• active
• not active
• active
• not active
• active
• not active
Sidemarker
Sidemarker (US)
• active
• not active
• off
• very low
• low
• rather low
• medium
• rather high
• high
• very high
Speedometer
Digital speedometer
• active
• not active
• true speed
• ‘corrected’ speed
• true speed
• ‘corrected’ speed
Tail gate/Rear lid
Unlock rear window
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
Tank
• off
• 20 km / 12 mi
• 50 km / 31 mi
• 6.5 litres
• 8.0 litres
• 10.0 litres
• 12.5 litres
• 20.0 litres
Telephone
Telephone ringtone
• BMW
• Mini
Turn signals
Hazard lights
• standard
• double
Crash lights
• standard
• double
• 1
• 3
• 5
• 1
• 3
• 5
• 1
• 3
• 5
• 1
• 3
• 5
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
Video in Motion
Video in motion 1/2
• active
• not active
Video in motion 2/2
• active
• not active
Video in motion
• during driving
• only walking pace
• not active
Voltage Monitoring
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
• active
• not active
Warnings
Speed limit warning
• not active
• 120 kph / 75 mph
• 190 kph / 120 mph
• 210 kph / 130 mph
• 240 kph / 150 mph
Temperature warning
• active
• not active
• active
• not active
• off
• 20 km / 12 mi
• 50 km / 31 mi
• 6.5 litres
• 8.0 litres
• 10.0 litres
• 12.5 litres
• 20.0 lit
Varu saprogrammēt gan šīs, gan citas interesantas lietas. PM.
