RSVSR ARC Raiders Quest Guide: Power Out
The Power Out quest in ARC Raiders is one of the simpler early-game missions, but it's a key introduction to the Spaceport map and the tension of extraction runs. Assigned by Celeste, the objective sends you to investigate an electrical failure linked to a missing engineer, taking you to the southern edge of the map where danger can pop up anywhere. Completing it rewards XP, materials, and campaign progress, making it a solid choice for new players learning the ropes or for veterans stacking daily objectives ARC Raiders Items.
To start, drop into a Spaceport match and head south toward the Electrical Substation, which sits between the Security Checkpoint and Staff Parking. Your spawn location matters—a nearby start makes the journey easy, but if you land far away, you'll have to cross open ground while dodging ARC drones and other squads. Bring combat augments, a dependable weapon like a rifle or shotgun, enough ammo, and healing items. Patience is key: move carefully, use cover, and keep an eye on your surroundings until you reach the substation's fenced yard and humming equipment.
Once there, the quest updates to "Find any sign of the missing engineer." Look in the northwest corner of the yard, where a small metal crate or an engineer's bag sits, often with a slightly open lid or a glowing interact prompt. Interacting gives you a large power fuse, which you need to pick up quickly since enemies may patrol nearby. The step is fast, but making noise or moving carelessly could attract attention.
Next, carry the fuse southwest about 15 meters to the red-lit electrical box or generator outlet, usually tucked against a wall or panel. Insert the fuse, watch the brief animation, then flip the nearby power switch to restore electricity and complete the quest. You don't have to extract immediately, but it's smart to secure the area first—clear nearby loot or threats before celebrating, since the power surge can draw enemies. Experienced players can finish this in under two minutes.
What makes Power Out more than just a simple fetch quest is how it ties into Spaceport's broader map. It pairs well with nearby loot runs or other southern objectives, letting solo players treat it as a quick stop during larger expeditions. Squads can assign someone to cover the fuse placement while others handle threats. Timing helps too—doing it early when robot spawns are lighter gives a wider window before the extraction timer forces you north. Rewards are modest but accumulate toward unlocks, so repeating the quest for materials and XP is worthwhile.
After finishing, your log updates to extraction. The South Elevator northwest or East Elevator northeast are the best exits from this area. Heal, reload, and consolidate loot before heading back, since the return journey carries more risk—you're heavier and more visible to hunters. Planning waypoints, sticking with teammates, or dropping extra gear for a faster sprint are all smart strategies. Failing extraction means repeating the quest, which highlights ARC Raiders' high-stakes loop where a single mistake can cost the run ARC Raiders Coins for sale.
Power Out balances accessibility and danger, teaching players map awareness without feeling overwhelming. Its short, focused objectives provide lessons in positioning, preparation, and threat management that carry into tougher content. For anyone running Spaceport campaigns or dailies, completing this quest efficiently helps build momentum and takes raiders a step closer to mastering extraction runs.
